Question about Toshiba Satellite A15-S157 Notebook
Reboot I'm trying to reinstall the system it will not start from CD. Whats the key combination at start to be able to manualy set it to go from cd??? Thanks in advance
  • 99 Answers
Uhm i think its F8 at startup splash screen
Posted on Jun 25, 2008
  • Nathan Capriati Sep 30, 2008
    insert cd and reboot and hold down the c key
When i turn my acer emachine E725 2520 on the power button comes on but display doesn't whats the problem?
Hi percy goodface
Connect your laptop to a different monitor and see if the computer is working.
If it is then your screen is faulty...needs to be replaced.
If your computer is not working then try these tips.
How to reinstall the Operating system on your computer
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
1.Restart the computer.
2.When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
3.If you are prompted with a Microsoft Windows boot screen, press the Enter key.
4.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
2.When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
3.Press the CD-ROM drive eject button and insert the disc labeled System CD.
4.Close the CD-ROM tray.
5.Refer to on screen instructions to select either CDROM or USB CDROM.
6.The computer will boot from the Acer Recovery Media
7.When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Please take time to rate me.
Bud
Sep 27, 2012 | Acer Computers & Internet
Tip
To Reboot or recovery from CD/DVD problem with OS "Aser"
If you don't press the Alt+F10 key combination or use the recovery CDs, can you get into Windows? Boot with the recovery CDs in. When at the Acer logo during POST, press the F12 key. Then, select boot off CD or DVD. Alternatively, you can enter the BIOS by pressing the F2 key at the Acer logo and go to the Boot tab. There, you can set the CD/DVD drive as the first item in the boot order.
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery. Some manufacturer(s) (e.g. HP) place the recovery files to a hidden (mostly) partition of the hard drive, the others give a Recovery CD/DVD with the laptop.
or
  1. Press the start button from the start menu depending on your operating system(win 2000,xp)
  2. Press Ctrl+Alt+delete combination from the keyboard.
  3. If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds
N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot
or Shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually.A few seconds should do unless you have additional problems.
All the Best!
on Sep 13, 2010 | Computers & Internet
How do I reboot my ASUS EEE PC 701SD 7" 0.9 GHz
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Oct 30, 2011 | ASUS Eee PC 701 Notebook
I have installed Windows 7 Ultimate just the other day, for the second time. I am about to throw this pc out the window. It worked for a good day and a half. I worked on it doing my quicken files and...
Sounds like a bad boot sector,to fix this try booting from your windows 7 disk.To do that reinstall the disk into a cd rom drive and reboot the system,as the system starts to reboot tap the Esc key.Doing that will bring up the Bio's.Use the arrow keys to get to the Boot section,Once there set the Cd rom that has the disk in it as the first boot device,then save and exit.The system will reboot from the disk,you'll see a lot of scrolling words,that's the boot loader reinstalling.The system should now boot as normal and you can remove the Cd from the drive you will not need it to restart again,the system will see that the CD is not in the drive and will automatically find the C drive for booting purposes.
Hope this helps,good luck
Jan 23, 2011 | Computers & Internet
Hi, i cannot get inside windos xp. i'd like to reinstall or reboot my laptop. what am i goin to do? I dont have cd rom. pls. help thanks.
Without the XP CD, you're kind of stuck. If you can get one from a friend, it'll work fine. Once you get a disk, you can boot from the disk by setting your CD-ROM drive as the boot drive or run setup on the disk to start the reformat/reinstall process.
Dec 14, 2010 | Computers & Internet
I am having trouble reinstalling the operating system. THe message " remove disks or other media. Press any key to restart." There is nothing in the cd drive or floppy drive. I just want to do a fresh...
Insert the genuine Microsoft CD-ROM disk into the CD/DVD reader. Press any key to reboot the computer, reading from the disk, to start the reinstall.
Mar 26, 2010 | Compaq Presario 1200 Notebook
Gateway 9500 windows wont start
these are essential windows files you will need to reinstall windows in repair mode
set bios to boot from cd you will during boot up be asked to press any key to boot from cd press any key when widows loads all its drivers etc windows will ask what you want to do press r for repair and follow instructions
during setup windows will reboot a few times when it does do NOT press any key
Jul 27, 2008 | Gateway SOLO 9500 (7002886) Keyboard
HP PAVILION a305w
try getting into the bios and setting it to boot normally, turn off fast booting if its an option thats on, also, set your CD drive as the first boot devioce, then hard drive. Save and reboot, have CD in drive and just start hitting the F10 key as soon as it starts up, usually you hear a Beep when it detects that you are hitting the key for the boot options. HP pavilions where made to start and skip through the Post Process quickly to limit waitnig time, of course this sux when you want to boot from a cd.
You could try remove ing the BIOS Battery off the board and unplugging the system, wait a minute for it to discharge and put it back in, power it up and see if it lets you boot from CD.
Your bassically resetting the BIOS to factory defaults.
Also, i dont recomend buying HP Pavilions. i wokred on three seperate ones that a customer thought was a New machine ( this was back in 2001 ) but all the parts where 1995 parts, which means wghen they tried to upgrade to windows XP, XP doesnt have any generic drivers for hardware that old so nothing worked and yuo cant find any driver online that are that old.
Good luck anyway.
Feb 15, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Reinstall xp
You have to make certain that the system BIOS are set correctly to boot your CD drive first. If you BOOT sequence is set correctly any cd that is bootable should begin to boot first. So try I believe to depress F2 when you boot up your PC for the first time this takes you into the system setup. System BIOS, goto the boot menu and change the settings to make certain that your CD drive is the first to boot. When you reboot your PC make certaint the CD is in the drive before you reboot. In addition you will quickly see a sentence pop up asking you if you would like to begin setup, and if so, depress any key to boot from cd. This should start the process for you!
Oct 28, 2007 | Acer Aspire 3000 Notebook
Toshiba Satellite A15-S157 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
