Panasonic NN-H275 1100 Watts Microwave Oven
Problem for Panasonic NN-H275 1100 Watts Microwave Oven
Door
By jim_den on Jun 22, 2008
I cannot open the door. When I push in it doesn't release.
Same Problem
May 13, 2009
-   Door won't open when you push the button.-   Guest
Oct 13, 2008
-   When I push my door release button the door does not open. I read in a previous post to take off the control panel but I don't know how to do that and I don't want to take it down (OTR) and send it away. Any help would be appreciated!-   bushockeymom
Jul 21, 2008
-   Panasonic NN-CT756 Inverter Microwave Oven, the catches on the door do not work, they appear to be broken or moved out of place, therefore the oven will not close, only 18 months old and hardly used.-   Guest
Best Solution
posted on Jun 29, 2008
Very Helpful)
MicrowaveSvc
Rank: Guru  Panasonic Kitchen Appliances  Expert
Rating: 89%, 5354 votes
Please reply back with your brand and model number so we can help you better.
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
We're happy to help and we appreciate your thoughtful rating of our answer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic NN-H275 1100 Watts
Questions and Unsolved Problems for Panasonic NN-H275 1100 Watts
Do you recommend Panasonic NN-H275 1100 Watts Microwave Oven?
Answer
Answer
keypad stops working after few minutes. after waiting for while it starts to work again.
Answer
can you not invert blower motors to fume upward and not through the back
Answer
I have a Panasonic NN-SD986S microwave oven. Shortly after a power outage, I noticed the following:... (More)
Answer
The Microswave is running in demo mode. It appears as it is running with the light on and turn tabel... (More)
Describe your Microwave Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Oven Experts
Top Small Appliance Repairmen
in Sedona, AZ
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
