Question about Sony DAV-DX255 System
Push power protector
Home theater says 'push power protector'
  • 5 more comments
  • SteveW Jul 10, 2008
    Just bought DAV-DX255 new, was display system. I receive the "push power protector" message when applying power. I have checked all the speaker connections and the ventilation paths and all seem okay. I tried unplugging all the speakers and get the same result. Are there any more diagnosis steps to perform? What else could it be?
  • lafunda2003 Aug 12, 2008
    Sony DAV-DX255 System push power protector please help
  • Anonymous Sep 09, 2008
    piece of **** does the same thing
  • edmund_obh Sep 13, 2008
    same probelm
  • Anonymous Nov 04, 2008
    SAME PROBLEM!!
  • kendra_crrll Jan 11, 2009
    thats all it says........
  • Awordjeremiah Stephens
    Awordjeremiah Stephens Dec 13, 2012
    THIS IS THE SAME THING THAT IS HAPPEN TO MY SET DX255
I brought the unit to an authorized Sony repair depot and they concluded that all the power transistors were fried. They replaced the system board under warranty (at no charge) and the system has functioned perfectly since. Thanks for your help. -Steve.
Posted on Oct 29, 2008
Open your unit up, and unplug the speaker related wires on the backmost board, then try turning on the unit again...some simple soldering should fix the problem!
Posted on Oct 26, 2008
    still the same thing protector push power
4 Suggested Answers
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
Posted on Jun 24, 2010
welcomejee
  • 10594 Answers
SOURCE: I have Home Theater Sony DAV- DZ151Kb. Display
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Jan 14, 2011
Testimonial: "Thanks for the support, it really is a very good recommendation I will check if you are getting voltage to the integrated and review the external components. "
SOURCE: SIR MY DAV-DZ110 HOME THEATER WAS FLASHING "PUSH
ola tengo un problema esk yo tengo el sony dav-dz110 cinema esk cuando enciendo me sale push power protector no se por k sale esto si alguien me ayuda se lo agraseria
Posted on May 23, 2011
if your pushing the power protector to on back its a resettable fuse an you have another insue inside shorting it out
Aug 03, 2014 | Sony Dream Home Theater System, DAV-DZ120...
If it really says, "Push power protector", there should be a reference to it in your owner's manual. Check there first.
Feb 05, 2014 | Sony BRAVIA® DAV-HDX576WF Theater System...
Protector/push power comes on when powering up sony home theater. checked wires for shorts and cleaned air vent . what else can I do
Usually means there is a short in the amp section. Depending on the model, this can only be fixed by replacing the amp ic or the amp pcb.
Jan 09, 2013 | Audio Players & Recorders
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Dec 20, 2012 | Sony DAV-HDX500 System
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
SIR MY DAV-DZ110 HOME THEATER WAS FLASHING "PUSH POWER PROTECTOR" THAT WAS HAPPEN TODAY WHEN I PLUG IN AND TURN ON MY PLAYER TO TEST MY NEWLY BURN CD...
Oct 12, 2010 | Sony DAV-DZ110 Theater System
Code for making Sony DAV DZ270 region free
HOLA QUE TAL COMO ESTAN ... TENGO UN PROBLEMA CON MI DVD MODELO DAV DZ270 ENCIENDE PERO ME DICE PROTECTOR Y LUEGO PUSH POWER ...Y NO SE QUE HACER .....ME IMAGINO QUE ES PROTECTOR Y NO SE COMO QUITARLO ... ALGUIEN ME PODRA AYUDAR... LE AGRADECERIA MUCHO... GRACIAS
May 26, 2009 | Sony DAV-DZ720 Theater System
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
Sony DAV-DX255 System Logo
4,486 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
