Question about Maytag Atlantis MDE7400AY Electric Dryer
MAY TAG NEPTUNE DRYER BELT INSTALLATION
HOW DO TO THREAD THE BELT AROUND THE PULLEY AND THE TENSIONER PLEASE
  • 943 Answers
Hi thanks for the question go to repair clinic punch in your model # it will bring up the picture of that set up thanks the appliance doc
Posted on Sep 18, 2008
Maytag neptune mde6800ayw electric dryer
The tensioner pulley for the belt, oil it with 3 in 1 oil, NOT WD40, if it stops then you need to replace the pulley because it will come back :)
Jan 31, 2014 | Maytag Neptune MDE6800A Electric Dryer
Maytag neptune dryer belt off and loose
If belt is not broken, then the tensioner is not routed properly. Generally belt comes around drum, then around tensioner pulley then on motor pulley. Tensioner is spring loaded, so you need to pull up on tensioner to get belt around motor. Good luck.
May 05, 2017 | Maytag MDE9700AYW Neptune 174 Electric...
Changing a dryer belt on a Maytag DE410
in some models you do it from the front the drum sits on 2 bogie wheels and the belt sits behind ,lift drum off bogie wheels and thread belt around pulley it should be on a spring tensioner and it allows you to swing pulley up or down try to thread belt around drum and replace drum back on bogie wheels.... in some dryers you may need to thread belt on drum and then onto pulley good luck
Dec 18, 2009 | Dryers
How does the tumbler belt wrap around motor and tensioner?
First of all disconnect your dryer from power source. Remove the front door.Start from the motor shaft, the top of the belt must lying on the pulley. This is how to do it. Pull the pulley toward the motor shaft and let the top of the belt lying (rest) on the pulley, this will help the pulley to stand firmed and the drum belt will look tighten a bit.
This should solve your problem
Dec 05, 2009 | Maytag Neptune MDE4000 Electric Dryer
Belt installation for a maytag dryer model# sde305day
Usally put dryer belt around the drum first
then around motor the tensioner pulley has to to be pulled up when you do this to get the belt around tensioner then you release the tensioner pulley to put tension on belt
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Drum doesn't turn in maytag neptune MDE9700AYW
Just remove the screws around the vent tube in the back and you can see the belt tensioner laying there on the floor of the dryer.
Most likely someone turned the drum the wrong direction and the belt came off.
The belt goes through the opening in the tensioner and under the idler pulley and then onto the motor drive pulley. Make sure to have the tensioner mounted into the floor first.
It just slides over into a slot and then over to the other side as tension is put on it.
Jan 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
How to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Aug 29, 2008 | Dryers
Zanussi tumble dryer. no.TC7114W
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
Aug 07, 2008 | Zanussi TC7114W Electric Dryer
Where is belt on dryer and how to fix drum won't turn
The belt on a roper dryer is inside the body, accessed and changed as follows
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
May 07, 2008 | Roper REX4634KQ Electric Dryer
Belt came loose
BELTS DON'T JUST FALL OFF THERE MUST BE AN UNDER LYING PROBLEM.WHEN YOU FIGURE THAT OUT TO PUT THE BELT ON GET ON YOUR HANDS AND KNEES
REACH IN ONE ARM ON EACH SIDE UNDERNEATH THE DRUM WITH YOUR RIGHT HAND GRAB THE BELT (BE SURE ITS NOT TWISTED) WRAP IT AROUNG THE MOTOR PULLEY.
HOLD IT THERE, NOW WITH THE LEFT HAND PUSH THE TENSIONER PULLEY TOWARDS THE MOTOR
THE BELT SHOULD GO OVER THE MOTOR PULLEY FROM THE RIGHT SIDE. SO IF HOOKED UP CORECTLY THE BELT WILL GO DOWN THE RIGHT SIDE OF THE TUB-AROUND THE LEFT SIDE OF THE TENSIONER PULLEY TO THE RIGHT SIDE OF THE MOTOR PULLEY THEN BACK UP THE LEFT SIDE OF THE DRUM
GOOD LUCK=)
Feb 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
79 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
