Subtle rippling lines when playing HD
I have subtle rippling lines, that appear around images when I am in HD on my cable box or in Blue-ray. Also, it seems that my convergence on the upper right hand side of the TV is separating.
  • 8,617 Answers
Your convergence ICs may be getting weak as they last about 4 years give or take depending on how often the set is ov. The subtle lines may just be a faulty cable or a bad solder joint on the ground of your input board.
Posted on Jun 22, 2008
Have just bought a db=g2602 blu ray player.Doesn't play one DVD I tried will have to try some others.Picture is not in middle of screen.there is a green line at top of screen.
How about giving this Free Blu-ray Player a try?
Leawo Free Blu-ray Player software contains all media playback solutions you need for your leisure entertainment. It acts as free Blu-ray disc player, free DVD disc player, free CD player (video-CD), free HD video player (free 4K video player), free ISO file player, and free audio player (free music player). Being a free Blu-ray disc player software app, it plays Blu-ray discs for totally free, and downward compatible with DVD disc and CD discs playback, no matter they are commercial or regular. It's the best free software to play Blu-ray on Windows (including Windows Vista, XP, 7, 7, 8, 8.1, and 10).
Meanwhile, as free DVD player, it's not only a free DVD disc player, but also free DVD player to play back DVD folder and DVD ISO image file for totally free. It's also a free 4K video player to deliver extraordinary image and audio experience via 4K displays. It's cable of playing 4K video in MKV, MP4 and TS formats, 1080P videos in HD MP4, HD MKV, HD MOV, etc., 720P videos in MP4, AVI, MKV, and other formats, be it camcorder reordered footage, downloaded online video, or streamed video.
Best Free Blu ray Player Software for Windows Leawo Free Blu ray Player
Oct 17, 2016 | Televison & Video
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
Vertical scan lines
It sounds that there is a loose contact to some connection wires, the flat wires that comes in, and go out the T'Con board. Re-seat all the flat cables and check. http://electronicshelponline.blogspot.com/ Check this link too. It has screen shots to different faulty displays. Pull up older posts and compare with these images to your TVs screen, and make confirm. Remember, vertical lines can be due to a faulty LCD display screen too.
Jun 06, 2013 | Vizio SV320XVT 32 in. TV
TV screen doesn't light up for 20 minutes
sounds like caps in the powersupply are bad they take a long time to value up
Mar 01, 2010 | Sansui HDLCD-2600 26 in. LCD Television
How do i connect my blue ray Samsung ht-bt1220 2.1 to play through my sky hd box
Connect an optical lead from the sky hd box to the Samsung Blue Ray.
Then change the function button on the Blue Ray to Din 1.
Then change settings on Sky HD box to Dolby and this worked.
Jan 16, 2010 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Lines running through color images
it means the head is dirty clean your printheads
Feb 03, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
See lines in HD cable or DVD source images, also maybe a problem w/ color, see extra blue haze
It sounds like convergence problem to me. There are two ways to correct these concerns; Samsung does sell boards, so if you are handy you can replace the boards yourself. BUT I recommend calling a factory authorized service company. It isn't costly, the cost will run around $400 -$550.
Aug 14, 2007 | Samsung HCL4715W 47" Rear Projection...
Problems with subtly changing colors
What connection are you using, HDMI or component?
Also, on what source is the problem happening, through sat or through off air antenna?
If you're on HDMI I'd try component. Then, playback the affected video and see if it's reproduced w/ component.
If it's on ota only, you may have a loose tuner cable inside. It's easy to fix, you need a torx t-10 screwdriver. Unplug the unit, take the 5 torx screws off of the back cover, and on the right side you'll see 2 cables running from tuners in the front to a splitter that connects to the tuner for ota on the back right. Just make sure the connections are tight with your hands only, don't over tighten them. Also, make sure you don't touch the power supply when you have the unit open!
Apr 06, 2007 | Directv HR10-250 DTV Receiver
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
