Question about Panasonic PT-52LCX66 Projection Television
Horizontal lines and shadows
Hi, my set has started acting funny. It seems after its been on for a while, I get horizontal lines and a ghostly shadow image. Panasonic said to unplug it from the surge protector which I did to no avail. Any ideas?
  • lperlste Jul 02, 2008
    Signal source doesn't appear to matter ... same problem happens with a DVD or even if there is no video source -- I can tell by looking at the menus. Sounds like a service call is next.
  • lperlste Jul 21, 2008
    Well according to the authorized service center, the light engine needs replacing to a tune of about $1700. It's not worth repairing so I'm talking to Panasonic about what to do next. The set is less than 2 years old.
Good Day, lperlste;
Yes, I would for sure follow up with factory. Panasonic does have device that help reprogram the light engine. I for the name as of now but I will get back with you on this. Iv'e used it A couple times with Pan only and it does correct most light engine problems.
I'll get back and let you the proper device name.
Hold on, big IRISH.
Posted on Jul 22, 2008
Good Day;
Yes, sounds like you need the service call. Sorry, it was not a consumer fix, but make sure you seek an authorized repair company.
Good Luck, big i
Posted on Jul 03, 2008
  • 927 Answers
Good Day;
Try doing the same thing to cable/sat box. If to no avail call your signal provider, or possible your TV is experiencing a convergence problem, if picture is concave. Does it do the same thing when you play tape/dvd?? If it does it's the TV, if not the signal source.
Good Luck, big irish.
Let us know.
Posted on Jul 02, 2008
  • MICHAEL MULLINS Jul 21, 2008
    Good Day,
    lperlste;
    I hope you received some professional help with the service that was provided. Did they solve the problem satisfactory/
    Let me know, if I can help, big IRISH.
Why is there ghost printing/shadows on my xerox workcentre 7335?
Suresh,
You don't say if the ghost is a particular colour, by ghost I suspect you mean similar to a drop shadow.
Firstly run off an internal test print, one of each colour if the grid lines are fine and showing no signs of shadow then your problem is not an internal problem. Don't send a C,M,Y,K test print from your computer, you can't eliminate colours that way.
If you can pin the problem down to one colour it could be a particular drum unit. Investigate from there.
Good Luck.
May 03, 2015 | Xerox Workcentre 7335 All-in-one Laser...
HP w19b "shadow"
OSD has no shadow shows monitor itself is OK and problem is in cable. Barrow a cable from friend and confirm the result.
Regards,
Sep 02, 2008 | HP Computers & Internet
Honda VT 600 C Shadow heavy fuel smell
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Strong Fuel smell
Carbs gas leak ect
Honda VT600C Shadow VLX Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT600C Owner Manual
Feb 21, 2014 | Honda VT 600 C Shadow Motorcycles
Screen ghosting
Hi !
How old is your iMac ?
SOunds to me like it has been left on too long for too many years..
THese screen eventually burn in and then it's the end...
Sorry.
Mar 04, 2013 | Apple iMac 24" Desktop
Shadows/ ghost images...
i'm also had the same problem and don't know how to solve it. anyone can help?
Apr 03, 2012 | Wacom Cintiq 21UX
Ghost like shadows
It seems your TV Samsung HCM4215W has problem in convergence board and need to be replaced.
You can get that board from Parts Store on $76
If you have bit electronics knowledge and know how about tv repair, you can replace it by yourself or get help of local tv tech person.
Oct 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Blue shadows/ghosts
how old is the tv ??
if this tv is older than 5 years it may need to refill the liquid on the proyection bulbs and/or could have contaminats in the fluid causing the ghost and to fix that you will need a professional person to do it
Apr 03, 2008 | Toshiba TP55H60 55" Rear Projection...
Problem with shadows showing on monitor
LCD Monitor Shadow Effect
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this is very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
Solution: Keep the two cables - (power cable and monitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Nov 02, 2007 | Dell Computers & Internet
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Panasonic PT-52LCX66 Projection Television Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
