Question about Creda C362E Electric Kitchen Range
Old Creda double oven keeps runing when switch off
Model number EDO 200/202 which is a 20 years old Creda electric double oven.
The top oven cant be turned off. I have to shut down the circuit breaker to turn it off. Is there any one who knows which parts should be replaced?
  • ddwchu Jun 22, 2008
    Thanks for your reply. The problem is when you turn it off only the heating elements still on. All the lights and indicators are off. And this problem is intermittent. Sometimes I can turn off the top oven but sometimes cant.
    President:
  • 1,462 Answers
Sounds simple but look at the knob to see if it is cracked and hence not turning the shaft
Posted on Jun 22, 2008
  • douglas smith Jun 23, 2008
    two areas to look
    selector switch stuck in closed position
    if element has neutral switching, then a fault to earth at the neutral end of the element will cause this problem
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
How do I turn the timer off on my old Creda Hallmark oven?
I recommend replacing the entire unit. 20 years is well past the operational life cycle of the oven. You deserve a new unit for sticking with it for so long. Besides, the new ones are more energy efficient.
Jul 28, 2014 | Creda Kitchen Ranges
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Creda grill will not switch to oven when i shut the door
Model Number TGF334BCWF Gas Stove.....When I turn the burner on the top front right my oven is coming on without me turning the on. What is going on?
Feb 21, 2009 | Creda C362E Electric Kitchen Range
Halogen hotplate will not turn down
You need to fit a new regulator that controls the hotplate, as the other one is faulty.
Please rate my fixya solution.
Thanks
Feb 04, 2009 | New World E70DOa Electric Double Oven
Cant find the model number on a Belling Format cooker
Hi.
Try looking inside the oven, or at the bottom front
Nov 28, 2008 | Ovens
Creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Kitchenaid double oven shut down!
The problem is they overheat because hot air is drawn in by the blower and overheats the outer chamber of the oven where the thermo fuse link is. The one or two fuse links are blown simple replacement but have to remove oven (two person job) remove outer shell and find it (them) in the back of the oven. Also the fuse link wire going into the main processor is probably blown.
Sep 06, 2007 | KitchenAid Architect Series KEBC208KSS...
Creda C362E Electric Kitchen Range Logo
424 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
