Question about Bosch 24 in. SHU43 Built-in Dishwasher
BOSH SHU 3030 Dishwasher timer
Where can I find a new timer or the sequence diagram for the timer. Mine burnt one switch, (pump on) I onpened it and repaired it. After assembly, it does not switch off. (All other functions are correct) I suspect that the bottom cam was assembled in the in the wrongrotational position.
Please help!
If I can buy a new timer it would be great, just not a complete new washer.
Regards
Cobus
    Genius:
  • 1,142 Answers
This weblink will help you
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 22, 2008
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
My bosch shu5306uc / u12 doesn't fill with water and it ends up making a growling noise after running - will run forever and never cycle....
DANGER stop using your dishwasher HEALTH CANADA WARNING Health Canada has forced Bosh to recall SHU 53 models. Risk of fire see link below.
http://cpsr-rspc.hc-sc.gc.ca/PR-RP/recall-retrait-eng.jsp?re_id=631&searchstring=&searchcategory=&searchyear=&StartIndex=1&current=true
Dec 22, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Stays in wash cycle
Solution found in a defective SPDT 'Heater ON' switch which had burnt out, thereby causing an 'open' to pump solenoid, fill valve, and heater. Temporarily bypassing the switch confirms the solution. Buy either the whole switch panel (3 switches) from parts dealer or find a source for CW Industries part GRS2012-13.
May 27, 2009 | GE Dishwashers
Unit is dead: does not appear to have power
Hello chicagogunn,
Welcome,
You said,Your unit stopped working mid-cycle. You have verified that there is power to unit. Is there an internal fuse which could have been tripped? None of the lights on the control panel currently light.
There is a thermal fuse!
Go to this repair web site I listed below and you will see the diagram
1. Diagram Page 02 - CONTROL PANEL PARTS
2. The thermal fuse is, Item # 6 on the diagram.
3. Click on page two on the left at this site.
4. And then in the upper right corner it says Open This Diagram in a New Window
http://www.pcappliancerepair.com/model-display.php
6 8193762 Fuse, Thermal Electronic In-Stock $ 13.25
Let me know how you do!!
Huuum
Please remember to leave a rating!!!!
ALSO:
Here are four things that the repair manual says to check.
1.
Burnt or broken wires
Check for burnt or broken wires. This would include the wires on the timer and door switch. Also check the wiring connection where the main power connects to the machine.
2. Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a volt /ohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician
3.Door switch
The door switch is wired in series with all components on the machine. If the door switch is defective, the machine will do nothing. Check the door switch for continuity
4.No Electrical power
Ensure that the proper voltage is being supplied to the appliance. Check the breakers or fuses that are supplying the power to the appliance electrical outlet. You can use a voltmeter to test for voltage at the electrical outlet.
Thank you Huuum
Oct 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Jul 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 5300
Mine did that. I tried changing the timer but it didn't help. I noticed that the water level kept rising until the drain pump would be triggered by the overfill protection switch on the left side under the insulation. It turned out that the fill valve didn't close all the way and so the pan would never empty. A new fill valve (easy to install and cheap) fixed it!
May 11, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosh dish waher
Does it make the same noise when it's just filling or just when the motor starts? Usually just filling the dishwasher opens a valve and doesn't run the pump. If it makes noise during filling the valve may be getting hot and shorting, or may have a loose connection, or air may be in the water supply line causing the valve to bounce. If it takes a long time to fill the filter may be clogged.
Nov 30, 2007 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch dishwasher
Bosh shu 43 built in take 3-4 hours to cycle
Aug 04, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
412 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
bosch5
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
