Question about Canon PIXMA MP830 All-In-One InkJet Printer
Ink cartridge we are new at computers and pinters where is the ink cartridge located on my canon mp830 printer? i have to replace the ink
  • arla jean115 Jun 26, 2008
    i can't find my manual and i don't know where the ink cartridges are located. and cannot find the website
You can access the ink cartridges by lifting up from the front panel part of the printer.
Posted on Jul 01, 2008
See instruction manual. go to manu website and see their manual pdf file and should be helpful-with pictures.
Posted on Jun 22, 2008
Is there a video on canon pixma mp830 printers? How to change ink cartridges?
With the machine powered on, open the top cover (including the scanner unit). The cartridge carriage and printhead will move to the center. locate the cartridge needing to be replaced (flashing light or light off) push the clip at the front top corner forward and the cartridge will pop up slightly. Remove and replace. To replace a cartridge remove any nozzle clips and the airway seal tape. Slide the new cartridge into the appropriate slot angling slightly down the in. press down until it clicks in place. If it feels difficult , try again - don't force it. When done, close the cover down and your machine should do a self clean and go.
Jan 19, 2017 | Canon PIXMA MP830 All-In-One InkJet...
Copy and Alarm Button Flashing
Regarding your Pixma MP830 printer inquiry (Canon PGI-5 / CLI-8 ink cartridges) and A200 error message, most likely the built-in PRINTHEAD is reaching it's end-of-life and may need to be replaced with a new one. Typically, the average printhead only produces ~4000 to 5000 pages before it electrically fails.
For information on PRINTHEAD failures, please refer to our support page: http://inkjet411.com/?page_id=2934
However, let's run thru the full checklist to screen out additional variables:
Canon A200 Error, Troubleshooting:
Replace ink cartridges if they are empty:
At the risk of stating the obvious (frequently not so obvious in the heat of the moment), find out if the ink cartridges are empty. When in doubt, try a new Canon original ink cartridge to see if this corrects the error.
A data cable of print head is open:
Did you just replace an ink cartridge? Perhaps you shifted a data cable to the print head.
Replace PRINTHEAD if it is damaged. Refer to Canon.com for replacement part.
Turn off the printer for some time
In other troubleshooting tips we have advised any inkjet printer not seeing regular usage to run a test print page. If you are making heavy usage of a Canon inkjet printer, consider giving it a break. This will avoid saturating the printhead with heat, prolonging useful service life.
Update the printer driver:
If you have followed all this with no success, from the printer menu (not computer) push the buttons to get a demo or test page. If everything is ok when you do this, however you get the service error code A200 when you try to produce something productive, odds are good, the print driver the computer is using has gone south (corrupt). When printing on a network, a corrupt printer driver can spread like an unwanted virus. Depending on the network, a driver that has gone rogue may be seen as an updated driver, which network will 'helpfully spread' as an update.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
Canon PGI-5/CL-8 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=4SSnu4XhWG0
However, if your printer works routinely after inserting a brand new Canon OEM (original) PGI-5 and CLI-8 ink cartridge(s) in it, this will confirm the cause of failure.
Please visit http://www.inkjet411.com for more information or contact us directly at INKJET411HELP@GMAIL.COM
NOTE: For North American ink refill store locations and details on ink refill pricing:
Costco USA Ink Refill Service (453+ stores): http://www.costcoinkjetrefill.com
Costco Canada Ink Refill Service (52+ stores): http://www.ca.costcoinkjetrefill.com
Costco Mexico Ink Refill Service (38+ stores): http://es.costcoinkjetrefill.com/
Costco United Kingdom (select stores): http://uk.costcoinkjetrefill.com/
Fry's Electronics Ink Refill Service (34 stores): http://www.frys.com/ads/page51
Best Buy Canada (4 stores): Downsview, Sherway, Toronto, & Vancouver
Micro Center Ink Refill Service: http://www.microcenter.com/site/content/refill-service.aspx
(8 locations are providing ink refilling services)
-Thank you
Jan 14, 2014 | Canon MP830 All-In-One Printer
Need to replace ink cartridge
http://reviews.cnet.com/multifunction-devices/pixma-mp830-office-all/4505-3181_7-31785803.html
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Canon PIXMA MP830 all-in-one is saying "the type of printhead is incorrect, install the correct printhead."
The cartrige is what holds the ink, the printhead is the device that puts the ink onto the paper.
So if your out of ink, then you need a new cartridge, if you have a new cartridge and you are having issues printing good quality, then you may need a new printhead.
you can get the ink here: http://printerinkcartridgesearch.printcountry.com/canon-pixma-mp830-ink-cartridges.htm
printhead is about 49.95
http://www.precisionroller.com/k_canon_pixma_mp830_print_head/m114d8577c104/
Hope this helps!
Brad Nelson
Mar 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Defective Ink Cartridges for Canon PIXMA MP830
1. Just open and close the cover a bid, this will initiate new checking of all ink cartridges
2. clean the contacts of the inkcartridge chip e.g. with spirit
3. Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shon correctly
Jan 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Refilling ink cartridges
I don't recommend refilling your cartridges.If if is not done properly the will leak and create a mess in the machine. I would always recommend new manufactures cartridges or a reputable re manufacturer
Nov 29, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP830
pleaz alihn the new cartridde by programing or change the ink ,it may be dry
Sep 14, 2007 | Canon PIXMA MP830 All-In-One InkJet...
USB001
Aligning the cartridge has nothing to do with the problem of the u150 error that two of the same ink tank cartridges are installed. It's a defective chip in the ink cartridge, as soon as I placed a new cartridge in it worked like a charm. HOLD ON TO YOUR INK CARTRIDGE RECEIPTS, because if this happens to you and the cartridge is obviously new....the store of purchase should provide you with a replacement (+ if you don't want to make a 2nd trip, some stores have the mp830 on display and you can have them toss the cartridge in and check to make sure the chip is working properly). IF THE STORE WON'T REPLACE THE DEFECTIVE CARTRIDGE, contact CANON (USA 1-800-828-4040)and explain the problem & hopefully the will stand behind their product and replace the defective cartridge.
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
66 people viewed this question
old marine
old marine
