Question about Miele Vacuums
There seems to be a short in the motor of a Miele S716 vac. Water was accidentally sucked up about 2 months ago
    President:
  • 1,673 Answers
Are you sure about the model number, S716 doesn't come up. But it could be a bad motor, or it be a circuit board mounted by the motor.
Posted on Jun 22, 2008
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
Steam coming out of Miele S7000 upright vacuum cleaner
There is no steam generator on your Miele. It can only be smoke or dust. Are you certain it is steam. If you have sucked up water the motor could be in danger of shorting out.
Aug 12, 2013 | Miele Vacuums
Sucked up some debris with Kirby, now the motor is not running right.
1) see the diagram attached.
2) clean it
3) test the belt for broken or crack
4) motor can be faulty by enough pressure in the bearing and winding overheating repair or replace.
Jul 19, 2012 | Vacuums
Is not sucking. Water comes out fine, but when the trigger is released, the water does not get sucked back.
Without more input from you, it is difficult to know what the problem is. Do you hear the vac motor wining ? If so, then ther is a clog in the passage or there is damage to the vac motor/impellor blade. If no sound from vac motor, well of course it will never ****-up the water. YOU WILL NEED TO TAKE IT TO A GOOD HANDY MAN OR AN APPLIANCE REPAIR/VAC REPAIR CENTER. Good luck, Macgivor
Oct 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell vacuum cleaner has stopped sucking things up as well as it was when I first purchased it two months ago. It also seems to be pushing more air out than it is sucking up.
with most vacuum cleaners the problem stems from carpet fuzz (especially in new carpet instalations) to build up of pet hair I have repaired several vacuum cleaners & my solution has use a shop vac if possible 15 amps or more clean the hose, check the belt(s) or if is not bagless make sure you have the proper fitting bag happy repair
Aug 23, 2009 | Vacuums
Blue Moon Miele power head stops intermittantly
It is not a solid short. This is caused by static arcing in the wand and in the connectors from base to hose. I was able to fix mine by smearing some dialectric grease on all electrical parts in the wand(especially by the led switch) and in the three prong connectors at the base to hose. Have not had nay problems since doing this.
Apr 15, 2009 | Miele Blue Moon Bagged Canister Vacuum
Water was sucked into Miele Vacuum
the motor is shot.they cant handle water. you are looking at a very expensive repair. miele parts are about the most expensive around. next time look at a panasonic, or riccar. or for a lifetime vac, look at the Metropolitan, made in the USA(around $400)
Oct 14, 2008 | Miele Cat & Dog 326i Bagged Canister...
Shop Vac not working well
The only thing after the filter and bag is the motor. Do you have suction with the hose removed? If not then the hose is clogged. If you have some, then the motor is the problem.
Nov 18, 2007 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Open Questions:
Vacuums Logo
105 people viewed this question
Top Miele Vacuums Experts
Roger Potts
Mack Baxter
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
