Question about Canon MV730i Mini DV Digital Camcorder
Focus When I turned camera on I am only getting very very blurred image as if it is focused up really close. Image is also fuzzy. How do I get it back into focus, I have tried the T-W does this work?
  • Canon Master
  • 2,794 Answers
Switch it on auto (or easy) first and see if focus works that way. If your on manual (or P) You have to use the joystick on the display to control the focus. All you do is push the center button on the joystick, move the joystick down to focus, press the center on the joystick and adjust it left or right. Press the center on the joystick when corrected.
Posted on Jun 22, 2008
Camera on XDA trion focusses correctly for neat focus, but shows a blurred screen for distant focus. When originally switched on to the camera and '1x' focus appears by default, a blurred green...
Most likely you have activated the Macro function. Usually this function is illustrated by a flower icon. This function is used to shoot from very small distances. Deactivate the macro function.
May 07, 2011 | O2 Xda Trion Smartphone
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
Camera will not focus
yes i have the saem issue did you see the post about compressed air?
Nov 09, 2009 | Olympus FE-280 Digital Camera
Focus is blurred yet lense works in /out
check and see the min and max distance for focus in the manual. also slight movement can cause this also.
Oct 16, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
What is the solution
You are dealing with "depth of field", or simply put (?), the range from near to far of an image that appears in focus. To increase the depth of focus, the camera must be set to a smaller aperture (higher numbered). Using a wider angle lens helps also. Focusing on the mid-point (near to far range) will also increase the apparent focus range. This is one of the most complicated photographic issues, and much has been written about it. Google "depth of field" for about 4 million explanations.
May 26, 2009 | Nikon D60 Digital Camera
Very blurred image as if it were out of focus
Touch auto focus on your screen.!!! or go to SCREEN control and change the screen size.
May 21, 2009 | Casio Exilim EX-Z750 Digital Camera
Nikon D40 will not focus
on the right side of the view finder there is a little bar. Make sure it is all the way down. If it is in the up position then it will make the viewfinder, shouldn't make the images blurry though. Also make sure it is in AF not MF (auto focus and manual focus).
Oct 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Why are my flash images out of focus?
This could be due to any of the following reasons. 1) A dirty lens can cause whitish blurring of an image. 2) Light from the flash reflected back from the subject can cause blurring and a feeling that the image is out of focus. 3) In total darkness when AF measurements are impossible, the camera focuses for about 2 meters. Subjects that are closer or further will be out of focus. The Auto Focus Frame is red when AF measurements are impossible. In this case, use manual focus (MF).
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Canon MV730i Mini DV Digital Camcorder Logo
95 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
