If your saying the starter motor won't crank, make sure the battery has a full charge.
Note the starter components picture, If that is what you have, I'd check the starter relay switch. It appears to be underhood--firewall or rear of fender lining, passenger side.
See the two large lugs, that should be battery voltage to and from relay switch. The smaller terminal should be feed from crank position of ignition switch.
In the past on different makes and models I have used a large screwdriver to short between the two large posts at the relay switch, to see if starter motor will crank. If you try this, make sure tranny is in park or neutral and parking brake is set.
I may be coming in the back door to diagnose, but, It should lead to same place.
