Question about Yelo 800DVD DVD Player
Yel 800dvd I cannot get the unit to switch on. It's sitting showing an amber led and refuses to budge either via the remote or standby button. I seem to recall this is something to do with condensation but the units been installed for over 24 hours now
  • Anonymous Jul 10, 2008
    I have the same problem although I upgraded to a DVD Recorder 18 months ago and the Yelo 800 has been sitting in a box in a cupboard since then. It was only when I gave it to my parents this week, then plugged it in to their tv and found that the stanby button remains amber instead of red or green.
    Any ideas anyone?
Well I have a Yelo and the unit does do this sometimes.....it does sort itself out by switching off and pulling the plug out and leaving it for a minute or so....plug in and should be ok.....if not do the same again! I do not know why this happens but all in all the Yelo is a good unit...it just appears to have quirks! The plug out fix works for me!
Posted on Jan 04, 2009
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
Preamp stuck in standby mode
a flaslight bulb and batteries and couple of wires can be used to make a continuity tester.and also pls check the small pushbutton(power button)try the remote if theres any
Feb 04, 2014 | Adcom GFP-710 2-Channel Amplifier
Hi, My SONY CPD G420 monitor has suddenly stopped working - the front led is blinking amber. After power cycling the LED stays green for a few seconds before going back to blinking amber. I have verified...
just unplug the signal cable and see if it shows a warning! if it shows then the monitor is in some working condition! this problem mainly is not the monitors problem its the systems problem, it seem as if the system is in standby when u on it right??? it happens when the processor doesn't get supply or it refuses to come on! you will see that the red hdd load led will not light when u start the CPU; just open the CPU and unplug the smps from the board and blow the pins to clean them up and re-fix it and see it will work. if still it doesn't work try some other smps it will work! reply and revert back for more help with a vote!
Jul 24, 2010 | Sony CPD G420 19" CRT Monitor
Our Teac hdr2500t epg Guide stopped working showing only the programme times but not titles. This comes only a couple of days after it stopped allowing me to watch one programme while recording another...
Turn off the unit via the standby button on the remote and pick "passive standby". Next time you turn it on the epg will be back. The other option is to turn off the unit via the power switch at the rear of the unit.
Jun 29, 2010 | Televison & Video
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
Mar 03, 2010 | NAD C521 CD Player
I have a Viewpia LC-32IE21H which does not want to switch on.
For a three years old set, first place to look is the main power supply capacitors, at least the 5vdc standby circuit is working, the problem can be as bad as the main controller board, but look at the power supply first.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Televison & Video
Stuck on standby
Neovia Neo-3775: Standby Led permanently on amber when powered up with no screen or sound. Does not respond to remote or to TV controls.My problem is same as Ed's posted in 2009 - any ideas?
Jun 22, 2009 | Philips TP2785C 27" TV
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
I have a Carrier infinity model 38tdb037-3. The outside unit will not come on. the control board on the outside unit shows an amber led on status 2.it is a steady constant flash.the error is an apparent...
Have you eliminated the possibility of a high or low pressure error. Sounds to me like it's off on safety. Should have troubleshooting the flash right on the panel. Test your pressure switches for continuity.
Jul 13, 2017 | Carrier Heating & Cooling
Yelo 800DVD DVD Player Logo
71 people viewed this question
Top Yelo Televison & Video Experts
Electro Med Services...
Are you a Yelo Televison and Video Expert? Answer questions, earn points and help others
