when I push the start button to start the cycle (any cycle) all the lights flash on the lights panel! and the machine wont run, this is the panel where u can adjust the spin speed and tmperture
can you help the machine was purchased in september/october 2007
oh by the way the phone number on the front of themachine isnt in existance as in the number is not recognised
-   iM HAVING THE SAME PROBLEM!!!!
This machine is turning into a nightmare.
All the lights flash and its stuck on timer!!!
Please can someone help!!!-   zoe2008
Jul 17, 2008
-   My machine sometimes lights up all it's lights when a programme is set but it seems to settle down if you return the dial to the top position and start again. Also it did not do this for the first few times and the hose hasn't been touched or the machine moved since! Any other solutions?-   Walter48
I looked at the pipes that lead into the washing machine (HD vision) the water pipe was kinked!
Solved the problem myself, just took some lateral thinking haha
not bad for a female eh
Regards
Glenys
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Was this helpful?
Yes
No
Popular Solutions for Hoover H130E Front Load Washer
Hoover HSPF 157 The switches on the control panel have been pushed too hard and disappeared behind...
(More)
Hoover HSPF 157 The switches on the control panel have been pushed too hard and disappeared behind the panel. How do I remove the panel to refix them?
Start arrow and Super wash LEDs flashing, machine not at the end of the cycle, water still in the...
(More)
Start arrow and Super wash LEDs flashing, machine not at the end of the cycle, water still in the drum
my hoover visionhd 1400 lost power supply. used it earlier today and was fine. no lights blinking on...
(More)
my hoover visionhd 1400 lost power supply. used it earlier today and was fine. no lights blinking on panel when set to wash. pls help
