Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
My Samsung refrigerator will not cool
I have a Samsung French Door Bottom Freezer unit (Model RF265AASH/X). The digital temperature is showing "OF" for both the Refrigerator and Freezer compartments.
I have tried unplugging to reset as instructed in the manual but when plugging back in, it is still steady on "OF".
Everytime I try to set the temperature, it reverts back to "OF".
Please help....food is going to spoil..
Thank you.
  • Anonymous Mar 16, 2014
    Samsung RF266ABRS Bottom Freezer Refrigerator French Door didplayin 8888 with a blinking digit an it will not start
Press and Hold the power Freeze and Freeze at the same time for 3 seconds, (cooling off bottons).. That worked for me.
Posted on Oct 13, 2008
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Posted on Jun 25, 2008
Water is coming under freezer section of Samsung RF4287 bottom freezer French Door
You have a plugged evaporator (cooling coil) drain pan opening or drain line.
Feb 06, 2015 | Samsung RF4287HA
Freezer not working flashing -8
samsung unit are dual cool meaning as longer compressor don't fail refrigerator will work even if freezer fail and vice-verse. If freezer is not working and refrigerator must like you have defrost problem which is very common in Samsung unit, can be something as simple as a sensor or it can also be the heating element. also check the temp in the freezer it can also be the evaporator fan
Dec 20, 2014 | Samsung RF265AA Bottom Freezer French Door...
Code freezer demo
French Door: Why Does The Control Panel Display "OF OF" Instead Of The Temperature? If the control panel displays "OF OF" instead of the temperature, the refrigerator is in "Cooling Off" mode. In Cooling Off mode, the refrigerator appears to be running normally, but the compressor is off so the unit does not cool. Cooling Off mode is used by retailers to save energy when the refrigerator is on the showroom floor.
Note: Cooling Off mode is also called Demo mode or Exhibition mode.
Disable Cooling Off mode by performing the following:
  • Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
Source:
Why Does The Control Panel Display OF OF Instead Of The Temperature...
Oct 17, 2014 | Samsung RF4267HARS Stainless Steel French...
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Nov 16, 2013 | Samsung RF265AA Bottom Freezer French Door...
Temp sensor
Check for broken wires on your ice maker temperature sensor. On my model RF265AABP that was the problem causing display to read 88 88 with one digit blinking.
Jun 29, 2013 | Samsung RB217ABPN Bottom Freezer...
My French door Maytag shows that my freezer temp is -2 and my fridge compartment is 40, but both are not cooling. it is now room temperature inside.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Dec 24, 2009 | Samsung RF265AA Bottom Freezer French Door...
Samsung refrigerator Not cooling below 45 degrees
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
dffg
Mar 14, 2009 | Samsung RF265AA Bottom Freezer French Door...
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
907 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
