Question about Panasonic KX-TG2356 Cordless Phone
Re-registering the Handset is not working
I have gone through the procedures on page 51 of the manual, and it is not re-registering. I have gone though step 1 - Press and hold [Locator/intercom] on the base unit until a beep sounds; step 2 - Press and hold [Flash/call wait] on the handset, until "Handset registering is displayed. I then wait a minute or so, then the three beeps sounds and "error" is displayed. I have retried a number of times, and the same error is displayed.
  • johnrenning Jun 23, 2008
    The solution was this - unplug the base unit, then plug it back in again. It worked fine after that.
  • noelcullen May 12, 2009
    uniden 2.4 GHz cordless phone ..base ok ..spare phone constantly shows "please register"..n0 buttons show response on screen
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Posted on Jun 23, 2008
I purchased panasonic cordles with two handsets
model no kx-tg3031b.
to register the handset with the base i fallowed the
instuctions given in the manuel.
at the end the screen shows - erroer.
will you please guide me to register it?.
thank you
dr. Rajasekhar reddy.
Posted on Nov 03, 2008
How do I deregister my cordless Vtech Cs6429 so I can reregister it to work again? After running the battery completely down it's saying to register it but it keeps failing
To deregister all handsets, with all handsets in standby, press and hold the Find Handset button on the base for about 10 seconds (or until the In Use light turns on and flashes). Release the Find Handset button. Then press and release the Find Handset button again while the In Use light is blinking. (You have about 5 seconds.) Wait until the process is complete. You should see the registration message on all handsets.
If the deregistration process fails, you can try resetting the unit from a registered handset. Pick up the registered handset that is on the base. Then press Talk/Flash button and then Off/Cancel buttons. Then try again.
The manual for the additional handset, CS6409, that is available for the CS6429 has the de-registration procedure. That manual is available from the product page: http://www.vtechphones.com/products/product_detail/1604 . Click on the Support & Manuals tab. The direct link to the manual is http://cdn-media.vtechphones.com/media/p/document2/products/%7B9B67F082-6CC0-48CC-B7F2-23C65B10A4F1%7D/CS6409_UM_V3_20141202.pdf .
I hope this helps.
May 03, 2016 | Vtech Lands Phones
How do I register new handset for AT&T cordless phone el51359
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Dec 30, 2015 | AT&T Lands Phones
Have acquired an additional handset with charger. The screen flahes a 'Please register' message. How do I do this?
Assuming you do not have 5 handsets already, make sure that the new handset is fully charged. Carry it over to the base and press Find on the base unit. (This sends out a signal to the handset.) On the handset, press Menu and use the Up arrow to go to the line marked Settings. Press Menu to access this sub-menu. The line H/Settings should be highlighted. If it isn't highlighted, use the Up/Down arrows to navigate to this line. Press Menu to access this menu. Use the Up/Down arrows to navigate to the line Register. Press Menu again. Use the Up/Down arrows to select the base to which you want the handset to be registered. Press Menu again to confirm that base registration. Enter the system PIN for this base; the initial PIN is mentioned in the manual on page 35 and on page 54. Wait for the handset to indicate that it has been registered; it will say Registering until the process is finished. If you take too long to do the steps at the handset, the signal will stop and you will need to start over.
If you already have 5 handsets, you will need to de-register one of them. If the registration process does not properly occur and the issue wasn't taking too long, either the base or the handset is not communicating properly. If other handsets work, I'd suspect that the new handset is faulty.
BT Systems has the manual on the Freestyle 750 product site: http://btbusiness.custhelp.com/app/answers/detail/a_id/12103/~/bt-freestyle-750-user-guide . The direct link to the manual is http://btbusiness.custhelp.com/ci/fattach/get/223683/1232386209/redirect/1/filename/BT_Freestyle_750_user_guide.pdf . The procedure to register the handset is on pages 53-54 of the manual.
I hope this helps.
Nov 02, 2015 | BT Freestyle 750 Digital Cordless Handsets
Phone will not register with base
Would you try this procedure:-
First on the base station..press and hold paging/register key for 3 seconds
Than on the hand unit select function key and open "MENU"
select "SETTING" from menu and confirm (Ok)
Selecect "HANDSET" and confirm
Than select" REGISTER" and confirm
than enter "0000" as pin and confirm..
it will flash and it detects the base.
Take care..
Nov 14, 2009 | Siemens Gigaset S440 Cordless Phone
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-TG1100
yes!
sorry, it seems that they have no manual for this model base online yet. however, the procedure to reset handset numbers for the 1000N may work for you. there is a 15 digit number on the base unit. type that into the handset using the book (was on page 54 for the 1000n) for your 1100 and see if that will register the other 1100 to your base.
Nov 26, 2008 | Panasonic KX-TG1100 Cordless Phone
ModelKX-TG6051BSAYS NO LINK TO BASE MOVE CLOSER TO BASE, duh,i have it sitting on base all day,when go to make call it says no link to base.why? I did unplug roommates thought would work.But now cant even...
Your handset has somehow lost its ability to see your base. Try re-registering it to your base. To do so, at the handset push MENU 001 . Then at the base, push and hold down the INTERCOM/LOCATOR button down until the IN USE light begins flashing. Then at the handset push OK, and within a few seconds it should beep and be registered. If first not successful try again. If it still does not work, try de-registering the handset, then repeat the registration procedures I described above. Here is a link to the manual that describes these procedures, look on page 39. http://www2.panasonic.com/consumer-electronics/support/Operating-Instructions/details-KX-TG6051M
Feb 26, 2008 | Lands Phones
Siemens Gigaset 4200
Hello, Yes this happens when you add a additional handset to the system when all the intercom numbers are full. When registering a new handset, it "kicks out" on of the other handsets when it registers. The only way to correct that problem is to default your base and register each handset again, one by one. You won't lose your handset settings, but you will lose your messages and greetings, so check them before doing so. To default your unit, get all your handsets and go to your base. Unplug the power from your base. Hold down the page/registration key on the bottom of the base and keep it held down while you apply power to the base. After applying power, keeping the button down, count to 20. Then release the button and get each handset. Register each handset, and they will number themselves 1 through 4. If you need additional assistance, service or need to purchase another handset or base (you can register each handset to up to four bases to increase your range, this is unique feature in the cordless industry), you can go to www.cordlessrepair.com for all your Siemens cordless needs. Good Luck ! Let us know how it goes, we have a testimonial page on the website for people to leave comments on the technical tips or assistance they receive from our technicians.
Sep 20, 2007 | Siemens Gigaset 4000 Phone
Panasonic KX-TG2356 Cordless Phone Logo
721 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
