Question about Timex Expedition 40141 Wristwatch
Timex Expedition Indiglo light no longer works?
Had the battery replaced on my subject Expedition compass watch and now the indiglo light doesn't work. Also, where can i find instructions to reset the compass?
  • Anonymous Nov 03, 2008
    nb.n.ln.l
    New Friend:
    Problem Solver:
  • 11 Answers
In a word- shmutz. Soap residue, sweat, dust, dirt gets in the space around the outer button, so that it no longer acts as a spring loaded, self-returning button. You will see this if you remove the movement from the watch case and look at the little metal plungers under the four outer buttons and the "start/stop" button. Use some silicon lube or spray on the outer portion of each button and around the small metal plunger inside while you work the button and the plunger back and forth, until it no longer hangs up and glides freely. Clean/dry excess silicon. Check the corresponding areas on the sides of the watch movements (what the little metal plungers hit) to make sure the metal spring prongs are straight and not corroded (use emery cloth or steel wool to clean if they are). Do A/C reset. Test Indiglo button until you get it to work, then reassemble.
Posted on Feb 18, 2015
    New Friend:
Try pushing all buttons simultaneously to reset the watch. Worked for mine.
Posted on Jan 29, 2015
This solution did not work
Posted on Sep 13, 2008
  • 3 Answers
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Posted on Aug 18, 2008
  • Dean K Aug 18, 2008
    CORRECTION!!! The arrow on the back cover should point directly AWAY from the stem.
I have a Timex Expedition watch which I have had for two years. I have been wearing Timex watches for 30 years and this one just doesn't live up to my previous experiences and expectatoins. The "indiglo"...
mcdevito75 here, Sorry to hear of your disappointment with your Timex watch, thru the years quality of workmanship and parts may have fallen a bit, try a new battery in your timex, a high quality Battery. Anyway here is Timex Customer service number, 800-448-4639 Regards, Mike D
Oct 20, 2010 | Timex Expedition Perpetual Calendar...
Display disappears when Indiglo is pressed
That means your watch has two batteries - one for the movement and another one for INDIGLO. It may have just one battery, but in this case INDIGLO is taking up too much power. Replace the battery and you will be sorted. Rate me, plz.
Feb 19, 2010 | Timex Watches
Indiglo light does not light
Replace the battery for Indiglo function.
Feb 16, 2010 | Timex Expedition 84601 Wristwatch
Timex T49271 Expedition Indiglo button dead?
There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
Hope it may helps you;
Regards
VOTIT
Mar 23, 2009 | Timex Expedition 40141 Wristwatch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
May 04, 2008 | Timex Expedition 40141 Wristwatch
Expedition Indiglo Waterproof 50m
how much is this worth my uncle gave it to me
Jan 17, 2008 | Timex Expedition 40141 Wristwatch
Timex Expedition 40141 Wristwatch Logo
2,685 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
