Question about Mitsubishi WS-65907 65" Rear Projection Television
Ws-65907 I dont know how replace 0 repair that please help me.
    Guru:
  • 1,894 Answers
I wil surely help u sir.
please mention ur mail ID i wil send u a MS-word file at once.
Posted on Jun 22, 2008
S my picture not comming in clear and has lines threw it?
Misubishi----ws-65907 is the model number?
Two common issues here---one is convergence where picture is somewhat or very 3d looking---I can if model number correct tell you how to fix that and second issue is some models get black lines that look like interference which is a more difficult problem to deal with.
Let me know which best fits your issues.
Mar 13, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Picture becomes cloudy on my WS-65907 set.
You have a contaminated picture tube. One of the three (red, blue, green) will need replacement fluid. The best source with instructions on how to do this, is to see the website. TVRepairKits.com. They will have complete instructions and photos. I have used this site and quite impressed. Thanks for asking and show all hands of support!
Sep 01, 2011 | Mitsubishi WS-65907 65" Rear Projection...
Hi, I have the ws-65907 65", it was working last
No,this problems is not the projection lamp problems.The tv now have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like 300-350 for parts and labors.
Oct 26, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Tv not turning on
U know how to solders?Replaced the convergence ICS and all it resistors,should get ur power back.Tries Websites Tv repair World.com,Tvrepairkits.com.First check ur DM power board see not any burn parts first.
Jan 12, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907 tv will not power on
one of the two pico fuses that protect the convergence chips this model uses is gone--see attached photo--
NEVER change just the fuses---if one of the two fuses is blown--the convergence chips got them-----
there are several ways to proceed from here-check the two fuses indicated in the photo and tell me if either or both are bad.
SD TECH
Jan 03, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Picture Convergence WS-65907
TRY NEW CONNECTERS AND INPUTS,,THEN USE THE CONVERSION
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws-65907
I had the same problem with my WS65907. If you know a little about electronics and how to solder, you can fix this yourself. First you're going to have to carefully remove the PC board from the TV. There are four "pico" fuses located by the regulator. check the ohms across each one. I found two of mine were "open". I replaced them for $1.49 Ea.
Dec 31, 2008 | Mitsubishi WS-65907 65" Rear Projection...
I have a Mitsubishi Ws-65907 I know it comes apart in two pieces Iwould like to give this TV to my father How do I take apart the top fromt he bottom. Any help thanks!!!
There are 4 plastic plugs (2 per side) that cover the allen wrench screws holding the top to the bottom. You will also have to take screws out of the back and pull the speaker grille to unhook the control panel. After unhooking and unscrewing everything, the tv will split in half.
Dec 06, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907
can u please give me ur email ID so that i can send u a DOC file having all step by step instructions?
since it is very long i can post it here
Jun 22, 2008 | Mitsubishi WS-65907 65" Rear Projection...
WS-65907 picture problem
Try resoldering the convergence ICs mitsubishi has been known to be a little stingy on the convergence IC solder in the past.
May 15, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
