Question about Jl Audio 12W3 Car Subwoofer
12W3V2-D4 ENCLOSURE??? WHAT IS THE CORRECT ENCLOSURE TO BUILD FOR EACH W3? I HAVE 2 12W3V2-D4, BUT HAVE AN ARKWARD SIZE TRUNK. THE ONLY WAY IS TO HAVE TWO INDEPENDENT BOXES... CAN ANYONE EXPLAIN TO ME THE CORRECT ENCLOSURE!
    Problem Solver:
  • 8 Answers
They need 1.4-1.7 cubic ft per sub(ported box) less if it is sealed but I wouldn't recommend that, it sounds like ****. Google "Re audio box calculator" and use it to adjust your dementions to your application
Posted on Sep 16, 2012
Go online and try to find the owners manual or look at if u got it or call the manufacter or go to a car audio shop and ask
Posted on Sep 02, 2008
Need some tips on building a subwoofer box.
Do some research on the model of subwoofer and find the recommended box size, subwoofers need the correct box size to work to its full potential, and size in meaning the volume of space inside the box so if you cant fit your box in your trunk cut it down to the size you need but make it bigger as much as you took of if you have more room say in night for eg.i hope the heaps otherwise there is so much online about sub enclosures.
Aug 06, 2014 | Car Audio & Video
What size should i make the enlcloser
If looking for LOUD, ported enclosure is the way to go.
If looking for accuracy, build sealed. You will need approx 2 cu ft
To tune this 2 cuft box around 50Hz, you need (1) 4" round port 5" long.
MTX recommends an enclosure of 2cuFt ea. You will only be able to use 1 subwoofer in this application.
Even a sealed enclosure is recommended 1.25cuFt.
You can shove 2 in the vented enclosure, but you may not be happy with the outcome
Dec 02, 2010 | Jensen XS-1010 Car Subwoofer
Hi i have a 15"w3-d4 jl audio sub,can anyone tell me what size antype box i should use ie sealed or ported and the box dimensions
I've had a look at the JLaudio website and they recommend 2 box designs, a ported and a sealed.
The sealed box needs a volume of:
2.125 ft3 or 60.2 litres.
To get this you would need to build the box to these dimensions:
22" x 16" x 14.75" or 559mm x 406mm x 375mm
The ported box needs a volume of:
3.50 ft3 or 99.1 litres.
24" x 19" x 18" or 610mm x 483mm x 457mm.
The port needs to be:
3.0" x 10.9" or 76mm x 277mm.
The enclosure recommendations listed above are external dimensions which assume the use of 3/4" (19mm) thick material. If you are using 5/8" (16mm) thick material, subtract 1/4" (6.5mm) from each dimension. Do not use any material with a thickness of less than 5/8" (16mm) as this may compromise the rigidity of the enclosure.
• All enclosure volumes listed above are net internal volumes! Driver displacement, port displacement and brace displacement must be added to obtain the final gross internal volume. All enclosure dimensions above have already taken this into acount.
• When using two subwoofers in a common enclosure simply double the required volume and, in the case of a ported enclosure, use two times the recommended port(s). Likewise, when using three subwoofers in a common enclosure simply triple the required volume and, in the case of a ported enclosure, use three times the recommended port(s).
• We recommend the use of this speaker in a bi-amplified system using high-quality satellite speakers and a high-quality amplifier. We do not recommend the use of this subwoofer with a passive crossover (coil), as this type of device will adversely affect performance.
As you can see it all depends on the space you have available, whilst the vented box will give you a more efficient bass responce especially with the low range frequencies.
If you to go and look at the information about your sub woofer and find out all the information about building or buying the correct enclosure then this is the link to the pdf file I found:
The enclosure info is on page 3:
JL AUDIO 15W3 Tech Specs and box info.
Warm regards
Mike
Oct 12, 2010 | Jl Audio 15W3-D4 Car Subwoofer
I have a JL audio 12W3v2-d4 subwoofer which has two sets of terminals and i needto know how to wire them correctly as my old one only had one set of terminals . i bought it second hand and didnt get wiring...
Your amp is stable bridged mono at 2ohms, however, having dual 2ohm voice coils will drop the amp to 1ohm if parallel and will kill it. The cleanest possible way to run this amp and keep it cool with lots of headroom is to run the coice coils in series then run the amp in mono @ 4ohms. To do this, run from one voice coil to another, a jumper. connect positive from one voice coil to the neg of the other voice coil. Then connect the remaning positive on one voice coil and the neg from the other voice coil to your amp (positive left and negative right on the amp) If your amp has a switch for momo make sure it is on, some are automatic. Hope this helps
Jan 02, 2010 | Jl Audio 12W3v2-D2 Car Subwoofer
How to wire a JL audio 12W3v2-d2 subwoofer . there are two sets of terminals how are they connected two the amp
http://mobile.jlaudio.com/support_pages.php?page_id=161
THE ABOVE LINK WILL TAKE YOU TO THE CORRECT PAGE ON THE JL AUDIO WEBSITE THAT PROVIDES A NICE TUTORIAL ON CONNECTING YOUR SUBS. THIS IS FOR THE DUA VOICE COIL SUBS. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Need help im planning to build a enclosure for my s3.10.0 subwoofer, can someone advice what type of enclosure and what size it will be. Tnk u very much! hoping for good advice.
Hello marne_glenn,
Here's a link to Lightning Audio's manual for the S3.10.4.
The minimum recommended size for a sealed enclosure is .5 CuFt. There is no recommendation for ported.
Hope this helps.
Jul 29, 2009 | Lightning Audio S3.10.4 Car Subwoofer
Orion hcca 15.4 two woofers two d5ooo orion amps
if you want a nice thump or sound i suggest face them towards the back of the car that way the vibrations bounce off your trunk and hit you hard
thats how i have my 2 clarion 600's and thats the only way the pound good and they sound the best facing the trunk
Jan 10, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Will a jl amp e1200 kick a jl woofer 12w3v2 loud
yes a 1200 watt amp will do the trick.. the problem would be in the box the 12w3v2 sub needs a good size box and you should have one made for your car. and yes you will get the bass you want
Nov 16, 2008 | Jl Audio E1200 Car Audio Amplifier
Dimension please for enclosure 12w3v2-d2
Typically you use one cubic foot per sub, so a 2 cubic foot box will work fine. To build a basic one, just a rectangular box, using 3/4" MDF (excellent material for a box), cut pieces this way:
2 - 25.5" x 13.5"
2 - 25.5" x 12"
2 - 12" x 12"
This will give you an interior volume of exactly 2 cubic feet. Cut your sub holes out of one of the 25.5" x 13.5" pieces.
Sep 24, 2008 | Jl Audio 12W3v2-D2 Car Subwoofer
12W3V2-D4 ENCLOSURE
12W3v2-D4 sealed or ported enclosure use.
Sealed 1.25 ft3 23" x 14" x 10"
Ported 1.75 ft3 29" x 14" x 12.25" - Slot port size 1.375" x 12.5" x 23.75"
12W3v2-D4
Fc: 47.4 Hz F3: 41.3 Hz Qtc: 0.83 Recommended Port Tuning: 30.3 Hz
Maximum wattage: 600 watts per driver.
I hope this helps you, more info can be found at: http://mobile.jlaudio.com/pdfs/12W3v2_MAN.pdf
Jun 24, 2008 | Jl Audio 12W3 Car Subwoofer
Jl Audio 12W3 Car Subwoofer Logo
228 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
