Question about Brother Lay-In Thread Serger Mechanical Sewing Machine
Upper and lower parts hitting
The upper and lower loop parts are hitting inside the machine, causeing it not to sew
  • maudymc842 Sep 01, 2008
    I have the same problem with my Brother 934D, trying to correct the problem. Some of it is operator error, as I am getting better results everytime I rethread the machine. The main problem seems to be the lower looper. The thread jams inside the machine and then breaks. The other three threads are not breaking at this point. The machine sounds very noisy, and I can hear the needles hitting inside. I am about to give up and take it to the shop, which for me is 300 miles round trip.
    Problem Solver:
  • 13 Answers
It sounds like the timing of the loopers is out they will need to be reset correctly within millimeters. If not done properly they can hit and bend or break easily and most are not cheap parts. Best it goes to a repair centre as it will work out more cost effective than the damaged caused by getting it wrong.
Posted on Jun 23, 2008
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
Thread loops while I sew
i should know whether the loop is upside or downward, its opposite tension adjustment , if the loop is downward position, tighten the upper thread tension , if the loop is upward then tighten the lower bobbin tension
Feb 27, 2014 | Janome Memory Craft 9500 Computerized...
Upper looper hits lower looper
The upper/lower looper need realignment, requires a qualified technician to do this.
Oct 21, 2013 | Brother 1034D Serger Sewing Machine
Machine is jammed, it seems that the upper loop and lower loop are colliding and it seems to be jammed and not able to sew or run properly! have any idea how i can fix it? I tried adjusting the lower loop...
The upper looper is the first place to check normally. It is the one to slip first usually. At this point your best option is to bring it to a repair person and have them reset the loopers and check for any other damage or adjustments needed
Sep 13, 2013 | Janome MyLock 644D
My Janome My Lock 644D will not sew. The upper looper hits the lower looper and the machine freezes. Any ideas of how to fix it?
No I am having the same problem and sorry but your all wrong
its nothing to do with treading.....
my upper looper is hitting the lower looper followed by freezing up
I need help too...their tension is fine the actual parts are colliding
Nov 18, 2012 | Sewing Machines
Lower thread too loose
Big loops on the bottom of the fabric is NOT the lower thread. First make sure that your upper thread is correctly threaded with the presser foot in the UP position. Do a test seem. If you still have loops tighten the UPPER tension knob. Do a test seem.
If after several upper tension changes do nothing. Remove the upper thread and take some rather rough sturdy fabric like light weight denim and "floss" where the tension discs are then rethread... and try again.
Oct 14, 2012 | Brother XL-2600
My machine will not stitch....have tried every combination and it keeps dropping stitches
Start with brand new needles. Make sure you use sharp needles for woven and ball point for knits.
Remove all threads from machine. Open all covers,, including top cover (under thread tension). Remove all lint. Oil moving parts. Replace covers.
Thread your machine from right to left. In other words, start with the lower looper, upper looper, right needle, then left needle. That should solve your problem. Thread must be threaded in specific order and through every loop in order to work. One miss threaded loop will cause the machine not to sew properly.
Apr 16, 2010 | White Sewing Superlock 2000 ATS Mechanical...
Drawing up the lower thread
Check the needle to be sure it is installed with the flat side to the back of the sewing machine.
Mar 03, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sears Kenmore sewing machine model number 15358 tension issues
#14 needle is way big for cotton napkin scrap. a #10 is good for most lightweight fabric. #14 is for sewing denim or levis, like that.
the tension problems on almost all machines regardless of price usually fall on the upper tension. the lower bobbin tension is factory set and it's rare you should ever need to mess with it.
if you have a drop in bobbin (top loading), tighten the adjustment screw all the way and then back it off 1/4 turn. if your machine uses a shuttle bobbin, tighten the adjustment screw all the way and then back it off in 1/4-turn increments until you can hold it in the air like a yo-yo and cause to bobbin case to fall slightly dipping your hand.
A dull needle and stitch length will also mess up your stitch. The idea is to narrow the problem down to one thing and one thing only -- UPPER THREAD TENSION.
So, if you have the right size needle for the job, with the right thread, and if your stitch length selection is correct (usually between 2 and 3 or 8-to-10 stitches per inch, the problem should be with your upper thread tension.
An easy way to fix this then is to remember: Loops on top, upper tension drop. Loops below, upper tension grow. If you get loops on top of your work, lower (drop) your upper thread tension to a lower number. If you get loops on the bottom, raise the upper thread tension.
Different stitches on the same machine will require different upper thread tension settings. Don't be afraid of it. Just remember the pneumonic: loops on top, tension drop, loops below, tension grow -- referring to upper thread tension.
have fun :)
Apr 15, 2009 | Sewing Machines
Brother Lay-In Thread Serger Mechanical Sewing Machine Logo
229 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
