Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
I need the general operations manual for a Jenn-Air Wall Oven-Model # W132W
How do I find the manual for this oven. The oven is about 9 years old and I've looked all over the internet.
Can you help me?
Joan Collins
joan_collins@sbcglobal.net
I had a simular problem looking for an older model for my mother. You might want to try this web-site address I found. http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JJW8530C&siteCd=JA_EN_US I hope it helps.
Posted on Jun 22, 2008
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air wall oven owners manual
You will find the manual you need to the following link. Just add the model of your oven
http://www.managemylife.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=JJW9327DDB11+JENN-AIR
Nov 25, 2010 | Ovens
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My jenn air single oven does not maintain temperatures, when set at 350 it shows 250. It is 15 years old, model #br is W131B
this is what you most likely need. Age, or the clean cycle, can cause them to start to malfunction.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-W131B-%3d%3di1364&PartID=1364
It is inside the oven, and comes out/goes in pretty easily, but you have to be careful when removing the old one, not to loose the wires in the hole, because then you have to pull the unit out from the wall and remove the back in order to plug the new one in.
May 06, 2009 | Jenn-Air JJW8530C Expressions Collection...
How do you get a Jenn air oven out of the wall???
The JennAir website should have the installation manual for download. Go there, type on your model number, and it should come up.
Sometimes these ovens just get "stuck" in place, and take some easy levering to break free, or to help you find other fasteners.
Jan 15, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Need a manual to operate five year old Jenn Aire wall oven
Jenn Aire model tag are usually at the opening of the door, or may have to pull unit out...be sure to check around the door before pulling out.
Jun 14, 2008 | Maytag MEW5527B Electric Single Oven
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
198 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
