Question about Fedders Heating & Cooling
Fedders window model A6Y12F2B "New Unit",,only 10 days in use! Just stopped working No Power To Master Panel Air Conditioner Not Working Fuse Panel/Breaker ok,Outlet ok,,power to plug ok(lights up) Reset button on plug functions normally Master Panel is dead, will not light up, non functioning controls
  • 104 Answers
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Posted on Jun 23, 2008
Does Fedders AEY08F2B window air conditioner have an oil port to stop squeaking motor.
Most air conditioner units don't have oil ports on motors any longer.
Sep 13, 2014 | Fedders Heating & Cooling
We have a Fedders window unit and we do not have an owners manual. When we plug it in it beaps and then blows air for 2sec and then it goes off with the signal E3 showing in the digital box. We need to...
Without the model number, I can't point you to the exact manual for your particular unit. However, here's a link to a web site that has about 38 manuals for various Fedders models. You can download a manual and/or users guide for free and look at the operation and troubleshooting sections to see what you need to do to get your unit working properly.
Just scroll down the page once you get to the web page to locate your particular model number, then click on it.
Hope you found this helpful and best regards!
Aug 06, 2009 | Fedders Appliance Air Conditioner Wall
My Fedders plug in AC will not start. Is there a reset button? The model # is A6X05F2B
Hi, yes right on you plug, if not, make sure there's voltage in receptacle, check your plug for any damages, your fan should be blowing, it seems to me you have no power in receptacle, check house panel for trip breakers, or you will have to go further, by removing front cover, with power off, and check master switch, sometimes master switch goes bad, if you don't want to go further call mechanic.good luck.
Aug 04, 2009 | Fedders AED24E7F Wall/Window Air...
My Fedders through the window AED24E7F does not turn on. I've checked the outlet and it still has power. I've flipped the reset button on the cord but that doesnt do anything. I just cannot get the...
If you can take out the thermostat, check to see that you have power on both connections. If not it may be a bad t-stat. If you can jump the terminals on this with at least a 12 awg wire and it starts, then thats the problem. If you do have power thru the t-stat then it may be the relay on the compressor. It will usuallly look fried if it's bad. Pull it off carefully (with unit unplugged). With an ohmeter, touch one lead to one of the three post on the compressor and one lead to the housing. Do this for all three. If you get continuity on any, the compressor is toast.
Jul 02, 2009 | Fedders AED24E7F Wall/Window Air...
Unit Turns Off
Have you checked the breaker in the breaker box to see if it's tripped? Also check the amp rating on the air conditioner and the amp rating on the breaker the unit is plugged into, the breaker may be weak or not a high enough amps or rating for the unit it's trying to power.
Jul 01, 2009 | Friedrich QuietMaster RS10J10 Air...
My Fedders air conditioner, that I purchased approximately 3 years ago, has developed a fan motor bearing problem. I would like a technician to come to my home, and repair the problem. Is this possible?
If this is a window air conditioner, an option is to remove from window and take to appliance repair shop for evaluation. It can also be repaired
at your home but is generally more expensive. In both cases, it is best
to have model and serial number available just in case still under
extended warranty.
Jun 26, 2009 | Fedders Appliance Air Conditioner Wall
Need Owners MAnual
Go to and then to this link:
to get your manual. If its not the specific one, put in ur request and leave ur email. They will inform you the moment they find one.......sodeep
Jun 25, 2009 | Fedders A6X05F2D Air Conditioner
How do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
Jun 15, 2009 | Fedders AEQ07FBG Air Conditioner
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
Does not start, manual nor remote
found fedders is bankrupt and another company is using the name
the tech there told me about the reset button on the other side of the plug, and the reset button worked
Feb 11, 2009 | Fedders A6Y12F2B Y Chassis Room Air...
Heating & Cooling Logo
186 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
