Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
