Central Air, its a Trane, cools, however not very well. I think it needs a charge
    Champion:
  • 254 Answers
First I would check your filters inside the furnace or air handler. Then if you have access I would check the a-coil. Sounds to me like you have a problem in the area of where the system transfers heat from the inside to the outside. Another thing that would'nt hurt would be to clean your condensing unit outside.
Posted on Jun 22, 2008
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane central air conditioner. Why does it blow one of the main fuses?
I might think the motor is shorted try to manually rotate the motor or fan if that is not it then you need a service man to fix it
May 20, 2015 | Heating & Cooling
Ac is set at 74 and it only cools to 80
system needs to be charged check filters and coils make sure they are clean first could be an air restriction issue to your intake
Jul 28, 2012 | Heating & Cooling
My Trane TWE036C140B0 is not blowing cool air i have turned off the TSTAT and still not getting any cool air the outside fan is working and the lines are not frozen
Sounds like your compressor is not running check your run cap. Most tranes I work on has a start cap it will be a black color and the run will be a shiny silver. If you have a multimeter you can check the caps. You will need a meter that has micro Fards and the caps have the ratings written on them.
Jul 30, 2011 | Ruud Central System Air Conditioner
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Price for TRANE BLU055E936B1 gas valve?
ARE YOU SURE ITS THE GAS VALVE ? ARE YOU GETTING YOUR VOLTAGES TO THE PV---28V. PV--MV - 0V & MV-GROUND 28V WHEN CALLED FOR? THEN LOOK ON THE INTERNET OR E-BAY.
Dec 01, 2009 | Ruud Central System Air Conditioner
TRANE 1984 Home A/C Where are How to Clean Coils inside House
the best thing to do it with airhandler shut down at breaker. 1st soften dirt and crud with 409 or different brand. 2nd take a wire brush and clean in up and down motion following the fins on coil.3rd rinse with spray bottle . this is the best you can do without coil removal.
Jul 02, 2009 | Heating & Cooling
How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
You should be clean and ready for the season
Jul 02, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
