Question about Kenmore 22812 Bagged Canister Vacuum
Power mate jr
My power mate jr, wont start.
  • Anonymous Jul 06, 2008
    what reset button? I am having the same problem if there is a reset button where is it?
    President:
  • 1,673 Answers
Did you push the reset? Check where the plug from the power head goes into the end of the handle. Sometmes the female plug gets pushed in to far, then the male part can't plug in and you will have no power to the power head. If this is the case, the the tabs on the tube inside the handle broke off and allowed the female plug to be pushed inside the handle. The other is the switch in the handle is bad, motor could also be bad. If you go to sears.com, click on the parts link, put in your complete model number and you will get a parts list and picture breakdown to look at and you can order parts here also.
Posted on Jun 22, 2008
Handi mate jr manual
Check and see if it's plugged in some place. That is a common happening.
Jun 30, 2014 | Hoover Vacuums
Power-mate jr belt appears to be loose, as will not turn brush. Can it be replaced? Looked online and could not find one.
Greetings,
You're in luck! I found the belt for you Powermate Jr. below; If you need help installing this belt, please start a new repair here on Fixya, and I'll be more then happy to walk you through the repair of this. If this helped, please be sure to click the thumbs up icon to rate it as helpful. This helps the Fixya community keep answering questions. Thank you,
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=8192011&productGroupId=0020&supplierId=116&brandId=x&documentId=P0601002&keySuffixId=NA&modelNumber=x&keyId=000010&pageId=00002&productTypeId=x&searchModelNumber=11625513506&subCompDesc=Attachments&brandDesc=KENMORE&modelDesc=CANISTER-VAC&blt=11
Mar 21, 2010 | Kenmore 25812 / 25813 Progressive Bagged...
Belt is broken
there is no belt on your model there is a reset button on the side by the brush
Dec 13, 2009 | Kenmore 31913 Progressive Direct Drive...
When using the vacuum (25812) with the powermate, the power shuts off - now it just stays off. The PM Jr. works.. could this be a problem with the wand rather than the powermate unit?
Check your lower and upper wand connects for pinkish or blackened evidence of burning. All connections should be shiny clean brass. Polish with wet dry # 600 paper or a scotch abrasive dish pad.
If the junior runs, with its tighter, cleaner less used connections it is very likely the wand connections and mating component, either the hose handle or power head elbow are also burned or badly worn. On a Kenmore, due to the weight of the head and mediocre design they wear in pairs and should be replaced in pairs. You can get some electrical parts thru a Whirlpool FSP parts center or a Panasonic dealer if you take in the matching pieces for clarification
Nov 01, 2009 | Kenmore 25812 / 25813 Progressive Bagged...
How do I clean the nozzle of my Hoover steam vac Jr?
No, this assembly can only be rinsed under running water.
Sep 29, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
My handi-mate Jr. is not spinning anymore. What should I do to fix it?
Assuming you don't have a broken belt, you can pretty much completely disassemble the Handimate and clean it out, which should fix "it won't spin any more." Part of the cleaning procedure is pretty obvious - there are tabs on the side that hold the top onto the bottom. Just lift the side flaps on the top section that surround the tabs to release the top section. Pay attention to how the thing is put together so you can reassemble it - there aren't many parts - it's not rocket science. Now the part that's not obvious: it's not too hard to pull the axle out of the cylinder to which the brushes are attached. Gunk, hair and fibers can get caught under the white end caps and around the axle.
Apr 09, 2009 | Kenmore Progressive Bagless Upright with...
Handi-mate jr. manual
I scanned my manual, but I can't fund any way to attach it here. I can send it to you if you provide your email address.
Mar 19, 2009 | Vacuums
Kenmore Model 116 PowerMate Jr stopped working
If the roller brush is not spinning freely once you remove it from the Power Mate Jr., then I have discovered the solution! There are end caps at each end of the roller brush. They seem to be permanently attached, but they are not. There is an axle inside the roller that is permanently attached to one of the caps. Take two pairs of pliers, and grab each end cap with a pair of pliers. Then pull hard to take them off. Once they are off, you will find that there is a big glob of hair wrapped around the axle inside. Remove the hair. Then reassemble the brush by putting the end caps back on. Make sure, when you put the caps back, that they are aligned so that they will fit back into the slots on the Power Mate Jr. You have to push hard to get the caps back on, maybe tapping one of them with pliers.
Oct 01, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
My Kenmore progressive 25513 506 Won't turn off
you need to buy a new pc board which is in side the canister between the motor and the power cord. first remove the lid. just pull it back real quick the it will come off. you might think you broke it but if done right it won't. now lift up but don't pull off the small lid in the back where the power-mate jr and look in the back for 2 screws remove those plus the 2 in front and pull the cover up. make sure to see where the wires are, if you don't the cover won't fit right when your done. between the pwr-cord and the motor is a pc board which needs to be replaced. just keep track of the wiring. if you can't do all this take it to Sears.
good luck
Feb 09, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 22812 Bagged Canister Vacuum Logo
106 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
