Question about Mitsubishi WS-65907 65" Rear Projection Television
Mitsubishi ws 65907
When turn on the tv in few seconds automaticly turn off.
    Guru:
  • 1,894 Answers
Do u hear a clicking sound.
this can be due to relays getting tripped
Posted on Jun 22, 2008
  • dewan nafees ahmed Jun 22, 2008
    ur power board may have been damaged.
    u wil have to look for blown out capacitors.
    mostly the DM board wil have gone bad.
    if u dont know how to replace or repair that please reply here.
    i wil help u.
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon.
2 Suggested Answers
  • 1894 Answers
SOURCE: mitsubishi ws-65907
can u please give me ur email ID so that i can send u a DOC file having all step by step instructions?
since it is very long i can post it here
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Tv not turning on
U know how to solders?Replaced the convergence ICS and all it resistors,should get ur power back.Tries Websites Tv repair World.com,Tvrepairkits.com.First check ur DM power board see not any burn parts first.
Jan 12, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907 tv will not power on
one of the two pico fuses that protect the convergence chips this model uses is gone--see attached photo--
NEVER change just the fuses---if one of the two fuses is blown--the convergence chips got them-----
there are several ways to proceed from here-check the two fuses indicated in the photo and tell me if either or both are bad.
SD TECH
Jan 03, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
Dec 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907 tv not turning on
Let's just buy new TV's to help stimulate the economy.........
Dec 14, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907
Jun 22, 2008 | Mitsubishi WS-65907 65" Rear Projection...
WS-65907 picture problem
Try resoldering the convergence ICs mitsubishi has been known to be a little stingy on the convergence IC solder in the past.
May 15, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Color Problem
look at this:
http://www.keohi.com/keohihdtv/brandspecific/mitsubishi/mitsu_calibration_mrbob2.html
then these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
