Question about Dynasty DGRSC 48-4GCB Gas Kitchen Range
Cleaning the griddle of our Dynasty Range and standard operations.
We bought our commercial range used from a reputable dealer who refurbishes these units and had it converted and installed by a professional. There is a little rust on the griddle. How do we clean that without damaging the cooktop. Also, when we run the griddle it appears as if there is gas flame coming through the metal grates at the back of the griddle? Is this normal? We haven't used it because we are unsure if this is how it's supposed to work, or if there is a problem we need to have looked by by a pro. Any advice you could give us would be greatly appreciated.
This addresses the cleaning question only. I was a chef for 27 yrs.  Once the griddle surface has begun to rust, and this can and even will be the case on a new stove, you have to get agressive with it. You're going to use sanding tools and oil.
If the griddle top is heavily rusted, I use my electric palm sander fitted with fine emory paper (the black stuff that can get wet). Wet down the surface with a small amount of oil and work the sander evenly over the entire surface in rhythmic strokes from front to back or side to side. I don't have a scientific reason for this but my gut tells me not to work in circles or random strokes. Try to work the entire surface evenly to avoid creating high or low spots. Use a straight edged spatula or I use a dough cutter (flat edge of about 4" and available from culinary store for under $10) to cleanly scrape  the dirty oil off the surface. Sand in shorter durations & clean often to avoid grinding dirty flavor into the surface.
Once you have it clean its time to season it. With a better oil focusing on flavor, spread a thin layer over the surface and cook at about 250 degrees for 15 - 20 minutes. Repeat this after every use until you build up a layer of cooked oil almost like enamel to resist rust between uses. This makes a teflon like finish to your griddle.
For regular use and cleaning scrape down immediately after cooking and while the griddle is still hot. When its cool use a hand sanding block you can get from the hardware store. The one I prefer is a firm sponge with emory paper wrapped around it. I store this in a bowl on the shelf above the stove because it is oily and dirty. Alternately you can also use rock salt and a kitchen rag to loosen food particles stuck to the griddle but this makes for messy laundry or throw away rags. We also use viengar or lemon juice and water to loosen food while the griddle is still hot or warm. NEVER USE SOAP!!!!!! You want your food to taste good don't you?
The oil used for cleaning can be anything with minimal flavor like canola oil but the oil used for seasoning the griddle should be a high heat type like sunflower.
Personally I only cook in black cast iron pans and the above method is how I treat them as well. Rock salt and water is all I ever need to clean them between uses.
Rick Casey
Posted on Mar 14, 2009
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
Does my griddle pan on my Frigidaire 5 burner
I just got a new range and the instructions to season the griddle are in the instruction book. Wash an d dry the griddle. coat all surfaces ( top and bottom ) with a thin coat of cookin oil. place in oven at 350F for one hour. turn off afer an hour and let cool in the oven.
Jul 02, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Is there a cleaning manual for my 6 burner/griddle viking range?
I have a product that I use to clean my burners and griddle with, it is made by ECOLAB and is called Greasecutter Plus. It doesn't hurt the range but it makes it look brand new, even my griddle comes completely clean. You just spray it on then let it sit for a bit then it wipes clean.
Apr 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Cleaning a grill
Vulcan has an online site that allows you to down load the operation manual for just about every model... here' s link... their op manual looks pretty helpful!
Vulcan site
May 24, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
GE 40" range griddle
You will have to check GE. With a model this old, it will be hard to find a replacement.
Feb 11, 2009 | GE 30" Self-Cleaning Freestanding Gas...
Dynasty DGRSC 48-4GCB Gas Kitchen Range Logo
687 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De GO PATS
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
