Question about Toshiba Satellite A135-S2276 Notebook
Screen goes black
What could cause this on my laptop
  • ccsweat Jun 22, 2008
    how can i go to that site if the computer screen is black?
There have been numerous issues with Toshiba Power saving settings on laptops that can cause the same problem. Sometimes a simple BIOS update will fix it. BEWARE: Updating the BIOS can kill the motherboard because your overwriting the core logic function of it.
Before you update make sure you have a fully charged battery to prevent a power outage from interrupting the process (usually the only thing you need to worry about). Go to toshiba.com and search for your model of laptop. Look for a BIOS update. Read their instructions thoroughly, then carefully follow them.
If you purchased it from Best Buy and are under a Performance Service Plan or even Manufacturers warranty (1 yr) then take it to Geek Squad, and let them get this shipped off and done for you.
-Mark
Posted on Jun 22, 2008
After I log-on my computer the screen goes black?
I've had this problem before and it was a fault in the multicore cable from the screen to the motherboard caused by constantly closing the laptop. It drops out when a demand is put on the cable. simple fix for an engineer.
Aug 28, 2014 | Acer Computers & Internet
My dell laptop keeps going back and forth from the loading logo screen to black screen
You might like to Power it off completely by removing the Battery for a few seconds.
If that doesn't help, try booting from your Win7 Installation Disk.
Apr 28, 2014 | Dell Studio 1537 Laptop
Turns on but black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 04, 2013 | MSI Wind U100-030US Laptop
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
When i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this.
Hi there, I am also facing same problem with my Dell Inspiron mini 1012, when i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this. S Bhat, India
Nov 01, 2010 | Computers & Internet
Sir sometimes my laptop screen goes black wats the problem
laptop screens tend to have a ribbon lead connecting the keyboard to to screen over time this wears (on some makes more than others) causing the screen to black out and eventually stop working all together.
you maybe able to get a new screen or ribbon on a site such as ebay or contact the manufacturer of the laptop.
Mar 19, 2010 | HP Compaq nx7300 Notebook
Dell Inspiron 1525 Laptop..the screen goes almost black after 5 minutes.
The screen goes black while in normal mode right? So try to boot in safe mode (power on then keep tapping F8 then select safe mode). Check if still happens in safe mode.
If screen does not goes black in safe mode it means there might be a software or driver causes problem when running in normal mode. You can try the following (update your anti virus software then run a full system scan, uninstall the video driver then download and install the latest one, uninstall any previous windows update or you can system restore to the time when it was working fine).
If the screen goes black even in safe mode they try connecting the laptop to an external monitor if still goes black, if yes then absolutely no issues with the LCD panel. You can try (uninstall and reinstall the video driver if still persist then this might end up replacing video card or motherboard, but before doing that update the BIOS first).
If does not goes black in ext monitor then the LCD panel might causes the problem. Reseat the LCD cable or inverter if you can.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Is it possible that my wireless network card is causing my laptop to not start. I have an Everex Stepnote VA4300M that goes to a black screen at startup. THe wireless card & monitor seem to have some...
it could be the culprit but it could also be corrupt system files, bad hard drive, bad motherboard. There could be a number of reasons why your laptop goes to a black screen.
The best way to tell if your wireless card is shorting out the motherboard to cause it not to boot is to take out the wireless card completely from the laptop and then turn it on and see if it goes past the black screen, if it does then you know thats the problem, if it doesn't then it could be some of the other reasons i mentioned.
Aug 10, 2009 | Computers & Internet
Screen flashes and goes black when you move mouse
some virus or spyware would have been the cause for tat...
go to start and then run,
there, type msconfig n press enter
in tat msconfig window, try clicking startup tab, there, try to remove tat virus startup, which would have been the cause for ur problem..
after tat restart and check, if it is solved
Jul 20, 2008 | IBM ThinkPad 770 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
