Question about Intel Motherboard
Installing lan port
Hi can help where can find the lan port drivers.. because i couldn find the driver.. pls help me...
  • 58 Answers
You need to go the MSI website and look for the driver. You'll need the model number of the motherboard..
http://global.msi.com.tw/index.php?func=downloadindex
Posted on Jun 24, 2008
Hi, the ethernet port located in the back of my computer appears to be faulty. I am unable to connect to a modem/router successfully due to this problem, also my USB ports don't appear to be working. Can...
If your lan card is faukty then you have to replace the LAN card. But as regards the USB ports not functioning the best thing to do is to install the usb drivers for your PC. When you install the USB port drivers for the PC the PC will be able to accept plug and play USB internet modems.
The drivers for your usb port can be located when you go to device manager select USB ports and it will take you to the drivers for the ports.
Hope this solution has been helpful?
Dec 30, 2010 | Computers & Internet
Not connecting to landcard
hi there
Can you be more specific about this problem so i can help you. there's could be
couple of things that can cause this problem ie. computer not recognize the card or your computer is not set up properly.
Nov 16, 2009 | Computers & Internet
Hp nx6115 lan driver how 2 install can u help me pls 6 times i have load window xp....for lan driver
Update the Operating System over the internet.It willupdate all the drivers.Make sure Windows Update is turned On.
Sep 09, 2009 | HP Compaq nx6115 Laptops
Wireless lan for Acer Aspire 5101AWLMi
what operating system you using? xp or vista? home? premium? basic? at any rate use this link to select your unit and use the operating system drop down menu to locate the software that is loaded on the computer. from there select the correct driver. Make sure you select the Lan Driver first. Load that. THen select either the atheros or broadcom driver. if you install both it will be fine. the machine will only install the correct one to the device. good luck!
Ruben
Aug 27, 2009 | Acer InviLink 802.11b (91.49C10.002)...
Not recognising lan
Go to the manufacturers' website of the Network card, They will have the driver for your card.
Copy it to your desktop.
Then use device manager to update the driver,
Control panel,system,device manager, network adaptors, click in here, driver tab, now update the driver, browse your Pc for it, it's on your desktop.
Should be good.
Hope this helps
Regards
Richard.
Apr 17, 2009 | AOpen MX4LR (91.89Y10.002) Motherboard
Lan driver
hi!!!
did you re-install the driver!!!!
Nov 22, 2008 | Intel D915GAV Motherboard
ADSL Modem Huawei SmartAX MT841 USB driver not supporting Window Vista Name update of Vista
Hi!
Do not use the usb port or cable. use the RJ 45 port instead. and configure PPPoE and connect using UTP / STP cable with RJ 45 connector straight crimped.
Jul 27, 2008 | Computers & Internet
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
Configuration of LAN fax
The best solution I use is Smart Net Monitor, which is supplied with the Ricoh disks or can be downloaded from www.ricoh-usa.com . First you need to install the lan fax driver, after that then install Smartnet Monitor.
From there click start, and then control panel, then printers and faxes, then right click on the Ricoh LAN fax driver, from there click properties, click ports, then click add a port, under available ports you will see smartnet port (highlite) and then select new port, a new box will come up and then select search, the software will then make the connection and add the port. Besure to click ok and apply and then you are connected
Oct 09, 2007 | Office Equipment & Supplies
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
