Question about Panasonic Televison & Video
Hook up instructions for panasonic sc-pt950 home theater
I am trying to figure out the hook up connections from Satelitte to Dvd Home theater to television..How do I get Dvd Audio to come directly out of television ..I get picture but no Audio,,Maybe I have wrong cables or something..Can someone give me either a diagram or explanation on cables needed and hookup..Greatly appreciated
You need 1 red and 1 white audio cables
Posted on Oct 26, 2008
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
Hooking up your surround to your television
Does your TV have an audio output? if it has, then connect that to your Insignia 5.1 ch. audio input.
Jun 07, 2010 | Insignia 5.1-Ch. Home Theater System with...
When i hook up my Bell 4100 Sat receiver to the Aux 1 in, i receive the sound but no video. I have tried using all sorts of combos, s-video and yellow video cable. The tv is hooked up witrh HDMI from the...
Thanks for clarifying that for me. The simple answer is the Denon home theater isn't able to convert the signal from your Bell receiver into an HDMI compatible format. You'll need to use either S-Video or the regular yellow cable to connect your Home theater to the television. The HDMI out provided would only work for the internal DVD player. This is a limitation of HDMI, not a problem with your home theater. You need HDMI in (or DVI in) to get HDMI out.
May 02, 2010 | Denon S-301
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Can't get surround sound for tv shows
The coby dvd 988 has 2 rca audio input jacks, you need to have these connected to your TV AUDIO OUT jacks, these are usually colored red and white like right and left stereo jacks, be sure to set up the TV for AUDIO output through these connections, some tv`s require that the internal built in speakers are cancelled and the audio output jacks are enabled. Set the coby input signal to receive the port you pluged the tv signal into.
Feb 06, 2009 | Coby DVD-988 Theater System
Need home theater hooked to TV with built in DVD
This is the easiest way 2 explain it. Hook up on the home theater should be labeled in and out. same as on the tv. The TV might no have that feature as the DVD is built in. You might just have an option for sound from the TV/DVD to the home theater. Again OUT from TV IN to receiver. Same with any other device set up.
Jan 27, 2009 | Durabrand 5.1 Surround Sound Computer...
Can't get the tv to play through the home theater
No they all are compatible with eachother no matter what brand tv,surrround sound. It is all in the hook up & without you stating how you have it hooked up,no way to tell because one siimple connection is all you r missing. You have it most way there if sound is ok on dvd.If you explain how you have it hooked up i can surley help you!!
Jan 23, 2009 | RCA L32HD31 32 in. LCD HDTV
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
Jan 12, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Televison & Video Logo
120 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
