High pressure tube cracked, cant find replacement part.
  • Bbuser Jun 22, 2008
    karcher power washer model k 2.26,electric
    Genius:
  • 1,036 Answers
Try looking here to identify the part number.
They will supply, but there may be supplier closer to you.
What is your nearest city?- And I can assist further if required.
If this fills your needs, Please rate as a Fixya! thanks.
Posted on Jun 22, 2008
I have a kenmore coldspot model 106.53532300 and the water will not dispense from the door the icemaker is working just can't get water from the door...really miss it! Can anyone tell me what to do?!...
Hello Ray;
My name is Peter. I am a retired field service refrigeration technician.
Ok, It may have been the water bottle. But, you have an old unit.
So, lets check it out once more.
1.) After time, from the heat, the plastic tubing for both your water lines to the water dispenser and ice maker will dry rot and crack.
Check: Pull your unit out. Have someone draw a glass of water from the water dispenser, while observing in the back both the water supply valve and the larger plastic tubing going to the water dispenser. Is there a leak when pressurized?
2.) Wait for when your ice maker fills and observe the smaller plastic tubing. Does it leak under pressure.
kenmore-coldspot-model-106-53532300-q5zw2lslmquh13tixvlr3ryr-3-0.jpg Part Number: Substitution: 4387492 Cost: $10.00
3.) Drain Pan - This too will crack over time do to heat. Pull your unit out so you can get behind it. Remove the lower back cover.. There are about 8 screws easily removed. Observe the drain tube from the under body of your refrigerator and the black drain pan where it empties. Observe around the drain pan. Are there and brown or dark stains on the floor? If so, then you have a cracked drain pan.
Repair: Unplug the refrigerator. The compressor and surrounding copper tubing prevent you from replacing the pan. When I was in the field, I would take duct tape and seal the cracked area. Then, I would cover the duct tape and surrounding area with a high temp silicone adhesive.
Mar 19, 2015 | Kenmore Refrigerators
Orafice tube location on 97 gmc yukon 4wd, cant find anywhere and my entire a/c system is unninstalled
the orifice tube is between low and high pressure line inside the tube. look on the tube mark .that what make low pressure from high pressure.
Sep 02, 2013 | 1997 GMC Yukon
Pressure only biulds to 50 PSI
Two things I'd look at first, the belt to see if it slips and check the water level in your tank, may need to drain it.
Oct 19, 2010 | Ingersoll Rand - Rand Type - 30...
Location of orfice tube
the fixed orfice is part of (crimped inside) the high pressure AC line, u must replace the line to replace the tube, the high pressure line is the smaller of the two lines from the AC compressor
Sep 02, 2010 | 1998 Mercury Sable
Intercooler to intake tube cant find replacement and mine has a hole the size of my fist
you will have to make that tube with a few pipe fittings and heater hose or high pressure hose and clamps
Jan 20, 2010 | 2005 Ford F 350 Super Duty
Danby DWM99W Top Load Washer - water over flows the tub - suspect pressure switch?
Two things to check. One ,when water is coming into tub, switch off at the plug and note if water stops or not.If it stops, then the solenoid is good. Remove the plastic pipe off the pressure switch and blow into the pipe. It must not be blocked. Clear if it is so. Check for any cracks:holes or breaks on the tube. Replace tube back onto pressure switch and remove opposite end. Blow softly and listen for a click. if so pressure switch is good. Replace tube and retry.
Oct 16, 2009 | Danby Washing Machines
Will not hold pressure. continous high pressure
is it possible to just tighten or add teflon to that fitting, just a suggestion, if tube nit cracked.
Aug 10, 2009 | Plumbing
I have an oceanic console with compass,computer , and air pressure. Now I am getting air leaking out by the compass hole. Can the pressure seal be replaced? Thanks for any help. Donald
It's probably the pressure gauge.. before you replace it, put it in some water to see where the leak is actually coming from. If it's coming from inside the gauge housing, it's time to replace it. If it's from where the hose is connected, there's a little spindle inside the connector between the gauge and the high pressure hose. Those frequently get corroded and start leaking. It's a cheap little metal tube with an O-ring on each end - those get brittle, crack and leak... the spindle is a cheap part at your local dive shop.
Apr 27, 2009 | Oceanic "Veo 100" Dive Computer Triple...
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Washing Machines Logo
Top Washing Machines Experts
