Before taking it apart, you need to turn off the cold and hot water valves under the sink. Once you have done that, open the faucet and let the remaining water run out into the sink. Since I am not sure what the age of your faucet is. I will be using instructions for a common Delta faucet.
1. There is a hole towards the bottom of the handle in the front. It may have a plastic button there. If so, pry the button off with a very small flat head screwdriver. Try not to damage it.
2. If your going to replace the seals, it is best to by the rebuild kit that comes with a special tool. It includes the allen wrench and spanner wrench in one. And all necessary parts to rebuild it.
3. Once you get the handle off, you will see a dome shaped part with two notches in it. It may have ridges on the side of it. That is the special fitting that holds all the parts down.
4. Remove the dome shaped part with the tool provided with the parts kit.
5. Replace all parts that match yours.
6. Install everything in reverse order and you should be good to go.
Don't forget to vote
Everyone have a great Thanksgiving
