Question about Cuisinart Supreme Grind CCM-16PC Grinder
Cuisinart grinder stem wobbles - Cuisinart Supreme Grind CCM-16PC Grinder
  • 8,596 Answers
Search Cuisinart's website for DBM-8 - that model has exactly the same parts as your Cuisinart. If you call them, they may even cover it under warranty.
Posted on Jun 04, 2009
Change or sharpen blade on cuisinart spice and nut grinder
you can replace it by contacting cuisineart on line and or their toll free number provide the part # and they will send you another one it will cost you though
Sep 30, 2014 | Cuisinart Spice/Nut Grinder
Replace the electrical circut board in cuisinart ccm 16pc grinder
Only an appliance, repair parts store can answer those questions. Look in phone book
Oct 01, 2009 | Cuisinart Supreme Grind CCM-16PC Grinder
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Cuisinart coffee maker grinder stuck in machine. Can't remove to wash
I fixed the problem on my coffee maker fast and cheaply! I found that the stem that the grinder sits on had a small crack vertically in the hard plastic. That caused the diameter of the stem to swell just a bit larger and the grinder to bind to the stem. My solution was to remove some of the material in the area that was binding on the stem. Since the motor for the grinder turns at a high speed, I let it do the work. A file worked very well for the job. I by-passed the safety cut-off plunger, by pressing a rod into it, hit the on button, then carefully held the file to the area to be filed. I then used medium sandpaper to smooth everything
If you try this, be sure to not take off too much material and only file in the affected area. Also we are by-passing the safety switch - so obviously use caution. I only did thiis a couple days ago but so far the ginder comes out very easily. Here are a couple picts.
Aug 30, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grinder wobbles
The model that you have is Costco's equivalent of the DBM-8 - the parts are exactly the same, so enter "DBM-8" as your model # on the Cuisinart website for parts.
Jun 22, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Install Cuisinart stem cover
I was able to replace my pieces thru Small appliance.com I ordered new parts and the directions on how to remove the old stem and put the new one on.
Put a little vaseline in the rim of the new stem. Use a wooden block and a hammer or rubber mallet and lightly tap the new one into place.
Cuisinart called two weeks after the fact to say I have to send them the machine.....
Oct 17, 2007 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart BGB-300
I just got mine to work. It seems that so much water condensation gets into the grinder that there was rust stopping the grinder from moving. Just remove all the parts, especially the blade and basket holder assembly. Take a pair of pliers and twist the grinder stem manually to loosen the rust. Turn it a good number of times and then test it out. I didn't want to use WD-40 on something my wife uses everyday. Good luck.
Aug 10, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart Supreme Grind  CCM-16PC Grinder Logo
254 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
