Question about Cuisinart Supreme Grind CCM-16PC Grinder
Cuisinart grinder wobbles - Cuisinart Supreme Grind CCM-16PC Grinder
  • Anonymous May 12, 2009
    The problem with wobbly stems and related failures to grind are all related to the cracked feed tube. This tube is removable, it screws out. There is no way to put pressure on the feeder tube unless you somehow load something into the barrel that won't "Grind". Assuming that didn't happen, it's likely a faulty design or part defect that should be repaired by Cuisanart. Our machine is less than a year old, purchased at Costco - maybe a mass sale by Cuisanart to clear inventory of a less than adequate design.
    One of the respondents indicated repair parts are available on the manufacturers website. A trip back to Costco or the noted website are the options I'll likely explore.
  • 8,596 Answers
The model that you have is Costco's equivalent of the DBM-8 - the parts are exactly the same, so enter "DBM-8" as your model # on the Cuisinart website for parts.
Posted on Jun 04, 2009
3 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart grinder stem wobbles
Search Cuisinart's website for DBM-8 - that model has exactly the same parts as your Cuisinart. If you call them, they may even cover it under warranty.
  • 547 Answers
SOURCE: My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Posted on Jan 30, 2010
Change or sharpen blade on cuisinart spice and nut grinder
you can replace it by contacting cuisineart on line and or their toll free number provide the part # and they will send you another one it will cost you though
Sep 30, 2014 | Cuisinart Spice/Nut Grinder
Replace the electrical circut board in cuisinart ccm 16pc grinder
Only an appliance, repair parts store can answer those questions. Look in phone book
Oct 01, 2009 | Cuisinart Supreme Grind CCM-16PC Grinder
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart grinder stem wobbles
Jun 22, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Cuisinart SS Grinder
try www.smallappliance.com for a replacement.
Nov 02, 2007 | Cuisinart SS Grind Central, removable bowl...
Cuisinart Supreme Grind  CCM-16PC Grinder Logo
322 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
