Question about HP Photosmart C4580 All-in-One InkJet Printer
Paper is constantly jaming - HP Photosmart C4580 All-in-One InkJet Printer
  • 2 more comments
  • Anonymous Aug 19, 2008
    always shows check paper after on or resume.
  • scampowl Feb 10, 2009
    the paper jams right under the inkjet.Thus the jet running back and forth quickly starts to tear up the paper.
    I thought it might be debrie in the last roller, but I can't figure out how to open more than the front door to clear out any possible debrie.
  • scampowl May 11, 2010
    My printer is an HP Photosmart C4580 btw.
  • longinos guereca
    longinos guereca May 11, 2010
    Paper jams are caused by many diffrent componets and situations. More information is definetly needed as to the type and location of the papaerjam. Most paper jams are associated to worn p/u or feed rollers. Debry in th paper path can also contribute to jams. The location of the jam is vital in identifying potential problems within a particular ***'y. Can you give me more information about the model of the machine and the circunstances for the paper jam?
Printer will jam if theres a piece of paper or something inside the paper loader, try to remove those stuff.
Posted on Feb 23, 2009
    Problem Solver:
  • 14 Answers
Open the rear access door of the printer which looks like a dark Grey plastic cover and after that is opened you will be able to see black rollers on a steel rod try to clean the rollers moving them upwards towards the ceiling and clean them with a clean moistened cloth. after they are cleaned let them dry for a min. after that the paper jam issue will not be there and ensure that you use a paper with a weight of 20-25 lbs. not more than that..
Happy printing.............
How do I correct the problem of constant paper jaming in Photocopier Sharp AR-51316?
Clean the paper detect sensors, 2 sensor in the top of paper cassette, one in right side of fixing unit, also check the
Jul 03, 2014 | Canon imageRUNNER 400S Copier
Our brother MFC 7420 constant jaming of the paper when trying to print, what causes this?
clean the drive wheels that pull the paper in, they get shiny after a lot of use, use a alcahol pad to clean
Mar 08, 2011 | Brother MFC-7820N Laser Printer
Xerox 5500 jaming at tray 3 and 2 constantly
There are mylar guide strips that get bent if paper is misloaded and the drawer is shut. Otherwise you need new paper feed rollers, which are part of the fuser maintenance kit.
Sep 28, 2009 | Xerox Phaser 5500N Laser Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
Paper jam
The issue is with the Paper Feeder roller , either its worn out and needs an replacement.
Apr 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
Misfeed Indicator light is on - there are no jamed copies present. Other solutions recommended. Thank you
Make sure that there isn't any little piece of paper caught near a sensor. Often when a jam is removed, the operator rips the paper, leaving some if it there inside. If it's near a sensor, you'll get a constant jam indication. Use a flashlight to check for it.
Feb 21, 2009 | Sharp AL-1642CS Copier
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Just installed a maintenance kit in my HP laserjet 5p now it won't work. Followed step by step cd on install. Printer worked before install. Printer keep given me a paper jam code (amber light at top)....
Did the maintenance kit include a fuser? If it did, then check to make sure you didn't break the sensor flag. If it's broken you'll get a constant paper jam indication. It's a movable lever usually where the paper comes out of the fuser.
Nov 29, 2008 | Office Equipment & Supplies
HP Photosmart C4580 All-in-One InkJet Printer Logo
180 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
