Question about Protron PLTV-32 Television
Need cdlarification... Can you elaborate - how do I know what specs on the higher ampage to look out for? [Sorry not very technical and need help on exactly what type of adapter to buy]
  • 2,071 Answers
Buy higher amperage value adapter...like for example 12 volt at 3 ampere if this not last long....then try higher amperage value 24volt at 6 ampere...or 24volt at 12 ampere......like this I mean...
Posted on Jun 23, 2008
How do find out what ampage my altenator is
Have a dealer run your VIN # on how it was built
Then you know what alternator to install
That # you gave us-- is of no use
If you take the alt to parts store they may have a way of
telling you what it is
Dec 07, 2012 | Cars & Trucks
Would like to change power supply to 12 VDC On Samsung LE37C580 37" LCD TV
The only way to do that is to buy a DC to AC converter...that is if you want to run your tv off of 12Volts DC. The converter converts the DC to AC so you can just plug up your set to the converter. The higher the ampage the better the results. Match your ampage of your tv to the converter ampage output. Just do a google search for "DC to AC converter". There are many availiable and many different prices. It is not practical to change the TV to receive DC voltage.
Jun 16, 2011 | Samsung Televison & Video
My philishave 384 not getting charged despite connecting to power and the charge light is also not geting on. How and where to repair it in kolkata ?
You need to replace the rechargeable battery by soldering a new ni-cad battery in place of the old one. Dont know the ampage required. Sorry. You need a torx 8 screwdriver to open it up.
Sep 27, 2010 | Philips Health & Beauty
Bike runs great for 25 miles new battery then startsto run bad and blows the fuse rplace the fuse turn the key to on and fuse gets very hot bike willl start after while but not well
how long since the coils & condensors were replaced if iether of these items are breaking down once they are hot the machine will comence to run poorly the fuse blowing is caused by the system building high resistance because the fuse is designed to fail at a predetermined ampage that is 15 amp fuses blow if they are subjected to a higher ampage than 15.you would be well advised to have reputable technician check your electrical system. good luck
Apr 04, 2010 | 1979 Yamaha XS 650 F
Circuit breaker type
Assuming the motor is OK start with a small fuse and if it blows try a bigger one. However the job of a fuse is not to protect the load (motor) but the wire that it is connected to. Be sure the wire size supports the fuse you use, if not you could have a fire. The information can be looked up on the web.
Good Luck,
Gil
Mar 01, 2010 | Electrical Supplies
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it...
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Feb 18, 2010 | Mitac Mio P550 GPS Receiver
Ampage needed for a 2003 Cadillac Cts
There should be a sticker on the old battery, either on top or on the side showing the cranking amps, and the cold cranking amps.
( if you still have the old battery).
Jul 16, 2009 | 1997 Cadillac Seville
My dryer doesn't appear to be drying as fast as before.
Most times this is because there is a restriction of the air flow leaving the dryer exhaust pipe. This will cause a buildup of heat and cause the high limit to turn the heat off. If clearing the exhaust pipe of crimps, dust or clogged line does not help then let me know. Thanks, Sea Breeze
May 27, 2009 | Maytag Dryers
Electrics
I've been taught to disconnect the battery when charging with a mains type charger. But I'm increasingly seeing the likes of the Oxford maximiser etc which come with a plug and flying lead to screw to the battery to save disconnecting. Anyone know the rights and wrongs of battery charging? Having replaced the batteries on all three bikes this year I'm taking a sudden interest.The new chargers also monitor the battery. They are designed to trickle charge when needed not to recharge from flat. The old type chargers charged at a much higher ampage and could build up an explosive mixture unless the caps were off. With them the battery should be out of the bike never in a confined space. The new ones charge at a much lower ampage, you don't need to take the caps off, or take the battery out. I plug one in every time I garage the bike, it keeps the battery in top condition and extends it's life. The battery in my Jackal is the original, now 6 years old and still good.,,,
Nov 10, 2008 | 2002 Moto Guzzi California Stone
Protron PLTV-32 Television Logo
24 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
