Question about Goodman CLJ30AR32 Air Conditioner
Goodman CLJ30AR32 Air Conditioner fan wont operate
Fan wont operate
  • 1 more comment
  • Anonymous Mar 06, 2009
    mi aire central no enfria tengo un problema con el ventilador de la unidad de afuerara no enciende cuando activo el sistema de enfriamiento
  • rm2711 May 17, 2009
    my fan outside is not turning, motor is very hot. fan blade does turn freely when moved by hand
  • burzerko
    burzerko May 11, 2010
    Which fan the inside unit fan or the outside unit fan.
Outside fan
Posted on Jun 27, 2008
Fans are run by capacitors.You need a multi meter that reads MFD's to check capacitors..
Posted on Mar 31, 2009
Ac fan wont work
Posted on Mar 09, 2009
    Champion:
  • 254 Answers
Outside condenser fan you can check the disconnect feeding power to the fan. You can also check for pressure safty switches on the lines coming from the compressor.
Posted on Jul 20, 2008
Where is the capacitor on the indoor unit of a goodmemson
It's attached to the motor inside the squirrel cage (blower motor fan) or mounted to the outside of the fan
Feb 05, 2014 | Goodman CLJ30AR32 Air Conditioner
The fan still running when the air conditioning stop in auto set mode
fan relay stuck if its on all the time. some use time delay to get the last bit of cooling off indoor coil then shut down
Aug 27, 2013 | Goodman CLJ30AR32 Air Conditioner
I have a CLK30-1D fan and its not working. Seem like that the only problem.
bad motor or bad capicator or lack of power to fan motor.............
May 10, 2011 | Goodman CLJ30AR32 Air Conditioner
The compressor runs but the fan dont. The fan runs in heat mode only
fan relay is bad at inside unit(air handler) it has one circuit for heat and one for cold.
Aug 12, 2010 | Goodman CLJ30AR32 Air Conditioner
It sounds like the condenser is running but the over top is not
I am assuming that the fan is not running but the compressor is? It is either the fan motor or cap. Hope this helps
Aug 09, 2010 | Goodman CLJ30AR32 Air Conditioner
AC working but no air coming in the house
Unit iced up or bad fan or fan relay. Goodmans have time delay fan relay and they go out often.
May 29, 2009 | Goodman CLJ30AR32 Air Conditioner
Goodman CLJ30AR32 Air Conditioner Logo
586 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
