Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer we had about 2 feet of ater in basement, trying to get dryer to work ... pushing start switch starts dryer but as soon as you release it , it stops
    Novelist:
    Scholar:
  • 70 Answers
Most likely the power board (which on this model sits at the bottom of the dryer) is damaged due to the water. The system starts but cannot engage the heaters and therefore shuts down as a safety precaution when the power board does not (can not) engage.
There is a fuse on this board that is probably blown but you really don't want to replace just the fuse. Because of the water damage the fuse blew because another component(s) is/are also bad. This is replaced as a unit and is easy to do once you have paid the exhorbitant price (in ours it was almost as much as two new machines from another vendor) for a new board.
Posted on Jun 22, 2008
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Maytag MDE2706AYW does nothing. It is getting power. Door switch is working. Thermal fuse is good. No power at yellow/black to door switch.
Hi sixtails. I found the wiring diagram for your dryer. My theory for your problem is.....
The push to start switch may be faulty not allowing electricity to flow past to the door switch. When this happens the dryer is unable to tell if the door is closed or not, not allowing the dryer to start.
You need to take the screws off the back of the console and take a look at the terminals of the push to start switch. Your push to start switch has two. You need to test for continuity across both terminals to see if it's faulty or not.
This is how you can do that:
1. Use an anolog volt ohm meter (about 10 to 15 dollars) and set the dial to the lowest ohms setting. You should get a reading of zero when the switch is pushed, when released; an infinity reading.
You could use a digital multimeter or a simple inexpensive continuity tester as well.
I hope you find this helpful and you have your dryer up and running soon. You sound as if you do have some knowledge of testing and troubleshooting, so that helps.
If you need any further assistance, I will more than happy to help.
Thanks,
Mike
Jul 21, 2011 | Dryers
The timer was a little tough to get started sometimes, I'd have to pull the knob out and push it back in several times before it would start.
The start switch is going out. You will have to replace the whole timer on this model. Check the first 2 numbers of your serial number if it is 10 - 15 the part number is 33002855 if the first 2 numbers are 16 or greater the part number is 33002803. Please rate me after reading.
Dec 13, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Kenmore Dryer model 63942 - Push statr button and the Dryer shuts off as soon as you release the start button
lint is stopping lever in motor switch....best use compressed air to clean it(should be 2 screws to remove it
Aug 25, 2009 | Dryers
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Start switch starts dryer but as soon as release d the dryer stops. Ifstart switch held in start position it turns and heats.
one of 2 things, your door switch is not working or the wires are shorted causing it not to work
Mar 26, 2009 | Dryers
My Kenmore dryer turns on as soon as the timer is set .
Two possibilities:
1) Least likely cause. Start button is not opening when released. Don't know how far you wish to go with this but it will require some troubleshooting.
2) Most likely cause. Motor start switch has a set of contacts that close when the dryer starts and this set of contacts "seals" around the push button. If this is the case, a new switch is in order. Switch is normally replaceable without replacing the motor.
Other option is use "as is".
Nov 20, 2008 | Kenmore 62602 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
46 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
