Question about Philips Magnavox 27MS343S 27" TV
DVD input with signal access
Have a DVD, Phillips/Magnavox (Oct99) Product # KT029940022009, Model # DVD825/173 with output on a Video-Audio connection to : the 2nd series Video-Audio connection to the back-end connections to a Phillips/Magnavox Smart Series TV, Model #MS3250C321.
Note: on TV the 1st series Video-Audio is used with our RF connection to feed a series of VCR, and Satellite TV and local aperture feed TV channel signals. VCR on channel 3 and Satellite signal is received on channel 4. Local TV channels are received on corresponding local active VHF/UHF channels, which are the following: 2, 5, 7, 9, 12, 16, 22, 26, 45.
The question is the following: How do we enable the second series Video-Audio port active signal from the DVD?
  • 8,596 Answers
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Posted on Jun 28, 2008
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
My TV is a Sharp-AQUOS Model # LC52D64U, I have 2 DVD players. SONY DVD player Model #DVP-S530D and MAGNAVOX VIDEO CASSETTE RECORDER/DVD PLAYER MODEL#MWD2206. Thanks Barbara
Sorry about the delay Barbara, I was looking for your clarification comments on the other question page. I didn't realize that you posted this information here in a brand NEW question box. No problem though, this will work just fine too. I will post the information on both question pages so there is absolutely no confusion.
First of all here are the links to each of the USER'S MANUALS for your particular system components:
SHARP AQUOS TV - MODEL # LC52D64U:
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC42_46_52D64U.pdf
SONY DVD PLAYER - MODEL # DVP-S530D:
http://www.docs.sony.com/reflib/docget.asp?manualid=8499&template_id=1&region_id=1&DL
MAGNAVOX VCR / DVD PLAYER MODEL # MWD2206:
http://download.m4c.magnavox.com/files/c/cmwd2206_f7/cmwd2206_f7_dfu_aen.pdf
To view the Owner's Manuals with Operating Instructions for each device, just use your mouse to click on the links, which are the underlined and highlighted text just above. Each one of them will open a new web browser page for you automatically and allow you to view the information indicated and the contents of the Owner's Manual.
You did not mention exacly what model of DirecTV receiver you have, so first of all, I will just give you the generic instructions for connecting that device to your TV using an HDMI cable connection.
DIRECTV CONNECTION TO TV
Make sure your TV and DirecTV receiver are turned off before making any cable connections.
Now connect the COAX cable from the satellite antenna to the COAX IN jack on the back of the DirecTV receiver.
Now connect one end of an HDMI cable to the HDMI OUT jack on the back of the DirecTV receiver.
Then connect the other end of that HDMI cable to the HDMI INPUT 5 jack on the back of your TV.
See page 10 of your TV's USER MANUAL for a detailed labelled diagram of the rear input connections on your TV.
Here also is a link to a short video which demonstrates this basic HDMI connection procedure:
http://www.youtube.com/watch?v=J7P-yayRJ6c&NR=1
If you want to test your system at this point, you can. Just plug in the power cords to the DirecTV receiver and your TV, then turn them both on.
In order to see the output from the DirecTV receiver, you will need to select the INPUT 5 input mode using the INPUT button on your TV remote.
See page 11 of the TV manual, button number 7 on the remote control button layout diagram.
Keep pressing the INPUT button repeatedly until you see INPUT 5 on the TV display screen.
At this point you should be getting an input signal from the DirecTV Receiver on your TV.
That completes the DIRECTV to TV connection portion of the system hook-up procedure.
SONY DVD PLAYER CONNECTION TO TV
Your Sony DVD player should have come with an S-VIDEO cable and set of RCA cables (yellow / red / white ) included.
Here is a link to a picture of an S-Video cable in case you need to see one:
http://amazingbestsellerstore.tk/wp-content/uploads/2011/08/31nOF2e5DXL.jpg
And here is a link to a picture of a set of 3 color RCA cables:
http://www.cameratron.co.za/images/productcables/cables/rca%20to%20rca.jpg
Connect one end of the S-VIDEO cable to the S-VIDEO OUT on the back of your SONY DVD player.
See page 8 of the SONY DVD Player manual.
Then connect the other end of the S-VIDEO cable to the S-VIDEO INPUT 2 terminal on the back of your TV.
Now take colored RCA cables and one end of the red and the white cables into the LINE OUT (AUDIO L / R) red and white jacks on the back of you SONY DVD Player.
Then take the other ends of those cables and plug the red and white plugs into the INPUT 2 (AUDIO L / R) red and white jacks on the back of your TV.
In order to see the output from the Sony DVD Player, you will need to select the INPUT 2 input mode using the INPUT button on your TV remote.
Keep pressing the INPUT button repeatedly until you see INPUT 2 on the TV display screen.
At this point you should be getting an input signal from the Sony DVD Player on your TV as long as the DVD player is turned on with a disc inserted.
This completes the SONY DVD PLAYER to TV connection portion of your system hook-up procedure.
MAGNAVOX VCR / DVD PLAYER TO TV CONNECTION
I will describe the connection procedure using the basic 3 color (yellow / red / white) cables which were included with the unit at purchase.
COMPONENT VIDEO cables are also a slightly higher quality option but would have to be purchased by you separately.
Take one end of the 3 color RCA cables and insert the colored plugs into the corresponding colored VIDEO OUT and AUDIO (L / R) OUT connections on the back of the MAGNAVOX VCR / DVD Player.
YELLOW cable plugs into the VIDEO OUT connector.
RED and WHITE cables plug into the AUDIO (L / R) OUT connectors.
See page 7 of the MAGNAVOX manual, METHOD 1.
Now take the other ends of the 3 color RCA cables and plug them into the corresponding colored INPUT 1 connections on the back of your TV.
YELLOW cable plugs into the INPUT 1 - VIDEO IN connector.
RED and WHITE cables plug into the INPUT 1 - AUDIO (L / R) IN connectors.
In order to see the output from the MAGNAVOX VCR / DVD Player, you will need to select the INPUT 1 mode using the INPUT button on your TV remote.
Keep pressing the INPUT button repeatedly until you see INPUT 1 on the TV display screen.
At this point you should be getting an input signal from the MAGNAVOX VCR / DVD Player on your TV as long as the DVD player is turned on with a disc or tape inserted and playing.
This completes the MAGNAVOX VCR / DVD PLAYER to TV connection portion of your system hook-up procedure.
Recording content on the VCR from an outside source will require additional connections which are described in detail on page 6 of the MAGNAVOX manual.
This completes the most basic hook up of your entire system using the cables which were supplied stock with each piece of equipment. As I stated, other options are available for purchase and the instructions for connecting these types of cables are all in the various OWNER'S MANUALS provided above.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Oct 05, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
I pluged this in & it wil not show up on my tv
You cannot use RF (channel 3 or 4) to see the output of the Magnavox. You need a RF modulator or separate video/S-video and audio inputs. The antenna signal is passed through the 2160 for analog signals.(and digital if you have a converter box or digital tuner)
tom
Jan 21, 2009 | Philips Magnavox MWR10D6 DVD Recorder
How do I know which converter box to buy?
here are the specs for the Magnavox TB100MW9
Product details Smart antenna ? No Closed Captions ? Yes CECB certified ? Yes Recorder ? No EPG ? Yes NTSC tuner ? No Analog cable tuner ? No QAM tuner No Component video inputs 0 S-video inputs 0 Composite video inputs 0 Digital audio input No digital audio inputs DVI outputs 0 HDMI output No Component video outputs 0 S-Video outputs 0 Composite video outputs 1 RF outputs 1 Digital audio output RCA output 480i Yes 480p No 720p No 1080i No 1080p No USB/USB2 No Ethernet No
Jan 04, 2009 | Televison & Video
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
Philips Magnavox 27MS343S 27" TV Logo
200 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
