Question about HP PSC 2410 All-In-One InkJet Printer
USb Printer Cable connection
I recently had a friend upgrade my clone to a new box. Unfortunately the USB connector socket for the hp printer cable was broken. Is there another method to connect the printer because of course the regular USB connector sockets can't work.
Please help
Thanks
Phil
  • HP Master
  • 2,794 Answers
Your stuck with USB. You can get another USB card to plug into your computer at a computer store.
Posted on Jun 22, 2008
Need a usb cable for the printer hp g55 to go into new win 7 computer the new computer has no parallel port only usb
These are the different types of USB connections. If you look at the back of your printer, you should see a socket that will take one of these connections. I've not seen the connections for a G55, but suspect its going to be a USB A (computer end) to USB B (printer end)cable. These are very common and you can buy them at most computer shops.
Nov 30, 2010 | HP OfficeJet G55 All-In-One InkJet Printer
Hi I have bought HP LASERJET M1522 NF printer and I did not use it as printer but as a fax machines but recently when I connect it to a computer it says USB is not recognised. I try factory restore and ram...
Since you haven't used it after opening the box, the usb port's connectors must have got rust on them. Disconnect the cable, clean the usb ports on both the computer and the printer using a soft brush dipped in alcohol/acetone. Also clean the usb cable terminals with the same materials.
After they are dried, you can try the connection, if the problem persists, use another cable and try it on another usb port or if possible on another computer. You'll be able to find out the culprit.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | HP LaserJet M1522nf Multifunction Printer...
I need a cable to enable connection from Epson lq 1050 to my computer - (DELL Inspiron-530S)
The "data" cable for a printer either is:
* USB -- a small almost-square socket, less than 1/2 inch (1 centimeter),
* parallel-port -- a very-wide connector, more than 2 inches (5 centimeters).
Some printers have *BOTH* connectors.
Determine which connector(s) you have, and buy a cable.
Often, a "Thrift Store" will have the "parallel-port" cable for a dollar.
Don't pay more than $4 for a "USB" cable.
If you're buying a USB cable, make sure that there is a "square" end -- some USB cables have a smaller "mini-USB" connector, in order to connect to a digital camera.
Nov 27, 2009 | Epson LQ-1050 Matrix Printer
HP PSC 750 will not scan.
OK I'll Give you three steps to try and then I'll give you a recommendation
With the usb cable connected unplug the power cable from the printer while it is on and wait for 30 seconds now unplug the power cable from the wall jack and then replug the power cable from the walljack and then to the printer.
now check if your printer gives the same error.
try another usb cable for the printer
Hold the usb cable with your hand and see if the status changes .If it doesn't
Its the usb port of your printer gone bad.
Its a nice printer hardly any problems to Hp customers at all,but unfortunately well you know what Im gonna say.
Anyway call in to hp at 1800-474-6836 and directly ask for an upgrade nothing else and you will get a 50% discount on an all In one printer.
with a years hardware and software problems covered.
you can extend this plan on the spot.
Now If you face any hardware or software issues then your printer will be replaced free of cost for hardware problems.
If its a software issue the hp tech will take a remote access of your computer and make your printer work perfectly.
Hope this will make you a little happy.
Jun 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Usb cable selection
no, just a standard USB cable.
Apr 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
I have just unpacked a HP photosmart C4205, which I'm unable to connect,because there is no USB cable in the box. Having looked at the connection area, it seems to be a specialised connection cable. It's...
hi,I also have a hp..and the cable did not come with the printer.you need a usb connector that will go into your printer and connect into the usb port on your pc.you will see that the connector is smaller for the printer connection so make sure you get the right one.usually called.printer usb connector in store.
May 12, 2008 | Office Equipment & Supplies
USB Device Problem after installing new printer
did you get a fresh set of drivers when you got that new hp? try this link, and advise your success on this.
Mar 09, 2008 | HP Officejet Pro L7650 Printer
HP PSC 2410 All-In-One InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
