Question about Kenmore 72802 Gas Dryer
Kenmore series 80 gas dryer not heating
Hi. I reset fuse, cleaned hose (which did have a lot of lint... even though I clean lint tray after every cycle).. but still no heat. I have no idea how to take off the back of the dryer or what to look for. Can you help? Thanks!
  • 4 more comments
  • jlyustman Oct 14, 2008
    I have a series 80, model number 11071812001 with the same problem. Today, I replace the gas coil valves (both) once is a 2 prong and the other 3 prongs. But that did not solve the problem. My next step will be to replace the igniter. Can you think of other parts for me to look at once I have it open. Thanks!
  • doc_218 Oct 21, 2008
    I have the same issue. The ignitor does glow, and the gas ignites for the first couple of cycles, but after about 20 mins or so in, the ignitor glows, however the gas no longer ignites. If I wait another 10-15 mins, and turn the dryer back on the same thing happens. I can get a flame for the first couple of cycles of the heating process and then after while the gas no longer ignites even though the ignitor is glowing bright orange.
  • cjjb1962 Dec 19, 2008
    how do you replace the gas coils on a kenmore series 80?
  • ajcalio Dec 27, 2008
    my dryer is spinning, but no heat.
  • Anonymous Mar 31, 2009
    I'm not sure yet but I think I need to replace the coils based on this synopsis. If this is indeed the fix then... most helpful.
  • jak of all Apr 25, 2009
    kemore series 80 not heating. How do I get the front cover off to access the coils and igniter?
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
2 Suggested Answers
  • 5 Answers
SOURCE: Kenmore 80 series. No lint
lint trap is blocked.Take off back cover, clean it out. un-plug it.theres about 15 screws
Posted on Sep 04, 2010
Testimonial: "Dryer is now working. Thanks for your advice."
Power indicator lights up but there is no power
Remove exhaust hose. Clean out lint. Remove back of dryer. Clean lint out of air flow system including lint and heat unit(coils). Try dryer. Is heat element glowing red hot? If not, replace heat element. They burn out intermittently and need lots of air flow to have good life. Clogged lint traps shorten life cycles. Definitely a DIY project. See youtube for general process.
Jan 09, 2014 | Whirlpool Dryers
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
Dec 12, 2013 | Bosch Nexxt 500 Dryer
NO HEAT
air flow. you must make sure that your dryer vent hoses are free of lint. if you found a lot of lint in the bulkhead more than likely your vents are cloged
Dec 02, 2013 | LG DLG0452W Gas Dryer
My dryer runs fine, just wont heat, was working fine this morning, but on my second load of the day it stopped heating, cleaned all the lint from front-even pulled out and cleaned the lint from the back...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 30, 2011 | Bosch Nexxt 500 Dryer
Dryer won't heat up and its not the element or thermal fuse....lint trap and hose are clean, any suggestions?
heatman101\][
Mar 28, 2011 | Kenmore 63942 Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
Dryer won't heat? Lint screen is clean, duct is
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 12, 2010 | KitchenAid KEHS01P Electric Dryer
Replace this fuse
Check THIS out
May 10, 2009 | Dryers
Takes two cycles to dry anything - even on High
first, check your breakers for the dryer. turn them all the way off and then back on. if it still doesn't work right, it needs to have all the lint cleaned out of the exhaust hose, and then the inside needs to be cleaned and the heating coil examined for damage.
Apr 29, 2008 | LG DLE5932W Electric Dryer
Kenmore 72802 Gas Dryer Logo
6,862 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
