Question about Virtual Reality VRCD500-SDU CD Player
Ipod connection i cannot play my ipod using the usb cable... help pls ...
If i had have know that then i wouldnt have brought it ,not a thing in paperwork saying doesnt work with ipod im really p****d off now.
Posted on Jul 13, 2008
  • 86 Answers
The stereo is not designed to interface with ipods through the usb. It will play by connecting your ipod's headphone output to the aux in jack on the face.A cable is supplied for this but i found mine to be noisy. A different cable worked fine.
My ipod is disabled
Plug the iPod USB cable into the bottom of your iPod. Plug the other end of the iPod USB cable into a free USB port on your Mac or PC. Open the iTunes application by using the dock icon on a Mac or the start menu on a PC. Click on the name of your iPod under the "Devices" list in the main iTunes window. Click on the "Sync" button to create a connection between the computer and the iPod. Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer. The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code. hope this helps
Attach a USB connector to the iPod and plug it into a USB connection on a computer for power, or into a stand alone USB charger plugged into a power strip for electrical power. Pick up the iPod. Move the "Hold" switch at the top of the iPod to the "Locked" position so that an orange color appears by the switch. Return the switch to the "Unlocked" position. Repeat this process. Press and hold the "Home" button and the button at the top right corner together if using a fifth generation iPod, iPod Nano, iPod Mini or iPod with a click wheel. Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod. Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo. Release the buttons. Wait as the iPod resets itself and turns itself back on. Leave the iPod connected to the USB connector so that it can fully charge the battery. Remove the iPod from the USB connector. Navigate to a song using the menu selection and play some music
Mar 01, 2013 | Apple Audio Players & Recorders
Kenwood KVT 514 in dash radio. Ipod classic is connected through the usb cable. Ipod is playing and showing onscreen progress, however, there is no audio coming out of speakers. Have been unable to make...
you need to purchase the ipod cable... your ipod is connected through the usb cable which does not provide sound to the unit but everything else works
Aug 15, 2010 | Kenwood KVT-514 Car DVD Player
I can't get my xo vision xo1915bt cd player to play my ipod. i plug it in using the usb n after a few mins of loading it goes back to the screensaver n says rep cancel. How do i get my ipod to play?
You cant get it to play your iPod with the USB connection. The only way to get it to play an iPod is if you hook up the AUX connection located in the back of the unit. get yourself a red/white to 3.5mm cable (3 ft should do) and run it through your dash into a location that will be convienent to put your iPod. The only other way to play an iPod is if it is one of the newer touch models that has Bluetooth. Then you can use the A2DP connection to play it wirelessly.
In short, the USB is only for charging your iPod, or playing music on flashdrives.
Dec 28, 2009 | XO Vision XO1915BT Car DVD Player
Ipod Shows as camera
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
But you will lose all your data
Sep 07, 2009 | Apple iPod touch
Ipod wont play on stereo
Re-check your usb cable, try to use the usb cable specified for use only by RCA RS2664b to connect to your ipod, if it doesn't work use the usb cable specified for your ipod because differrent appliances have diffrnt cable configurations.. ;-) hope this advice help you..... good day!
May 24, 2009 | RCA RS2664 Shelf System
Can't get iPod to play through factory sound system, pls help
u can buy a cable that splits from an audio output into the red and white cables so u can hook it up to anolog jacks
Jan 07, 2009 | 2004 Chevrolet TrailBlazer
Ford Fiesta IPod connection problem
You need the specific cable from Ford, part number 8M5J-19C142-AA, Finis: 1529487 which has a USB and an aux jack. It costs about £19. You need to plug in both aux and USB and then connect the other end to your ipod. You can then scroll through the playlists etc using the dashboard controls. When you have selected your choice, press the OK button and the ipod should play. You can use the steering wheel controls to move forward or back through the tracks and to change the volume. The instructions in the handbook are not very helpful.
Dec 28, 2008 | Car Audio & Video
On my pioneer DEH-50UB the error message 'ERROR 19' is constantly appearing, this is addressed in the mannual however it merley advices you to restart the unit. obviously this is not satisfactory when it...
To my knowledge, ERROR 19 on a Pioneer DEH series indicates failure on the USB connection. This is usually reserve for an iPod direct connection. If you are using such a device, pls:
  • check the Pioneer CD-IU50 USB Interface Cable;
  • reset the iPod;
  • disconnect the iPod and try again;
  • reset the Pioneer by removing the yellow and red connections. Pls note that some versions would require a security code when reconnected. Pls have this ready if and when your particular unit has a security/anti-theft feature;
  • reference page 32 of the manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | Pioneer Car Audio & Video
IPOD MP4- USB DRIVER NOT RECOGNIZED BY XP
Hello!!!
Try connecting to different USB slot!! and try changing the cable too!!
Oct 26, 2008 | Apple iPod nano
Virtual Reality VRCD500-SDU CD Player Logo
144 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Mark Skinner
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
