Question about Motorola Mobility RAZR V3c Cellular Phone
Not charging when charger is connected it shows "NOT CHARGING" MY PHONE DISPLAYS UNABLE TO CHARGE
  • Dj Scoobie Jun 28, 2008
    phone keeps saying unable to charge tried wall charger and usb charger for computer
  • Anonymous Oct 03, 2008
    my phone also says unable to charge.
Your phone charger might be the primary problem...
Posted on Jun 22, 2008
Charging problem
If you are unable to charge your phone, there are two possible reasons that can cause this, first, i suggest you get a similar charger to charger to charge your phone, if the similar charger charge your phone, it means the charger of your phone is the problem, but if it did not, then it mean the problem is the charging port of your phone.
The charging port of your phone is bad that is the phone is not charging, i advice you replace the charging port of your phone after you have confirm the charger is not the problem.
The problem is limited to two above, either a bad charger or a bad charging port.
Take care.
Jul 18, 2010 | Sony Ericsson W200i Cellular Phone
Won't charge
if the charger is good, then there is something wrong with the charging port or the battery.
If the battery is very flat before you charge, the charger would not be unable to wake the battery because the battery cell is weak. Its only a desktop charger that can wake the battery cell.
So, test your phone with another good battery, and if it still does not charge, then the charging port is bad as I said earlier.
Best wishes.
Jan 12, 2010 | Samsung M220 Cell Phone
I have had this charging overnight but it won't charge. What should I do?
Hello Friend,
It depends on what you mean by charging overnight.
1. When you connect the charger, it shows on the phone that it's charging but after a while if you unplug the charger, it's still not charged: if it's the case, that means the battery is dead and needs to be replaced.
2. When you connect the charger, it doesn't show the phone charging: in this case it can be the charger brocken or the phone charge connector is faulty. you can verify that by moving the charger connector a little bit and see if it will start charging, if not you can try with another charger. if it doesn't charge even with another charger, at this time i will say for sure that the phone charge connector is faulty and needs a repair.
Best Regards,
Oct 30, 2009 | Toshiba e310 Pocket PC
Phone displays "Unable to charge"; Help!
Clean charging port and remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Oct 28, 2009 | Motorola Mobility RAZR V3
Unable to charge battery
Clean charging port, remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Oct 19, 2009 | Motorola Mobility RAZR V3
My Nokia 1112 displays 'Test mode' only and doesn't switch on!
charge your mobile and while charging try to turn on.make sure the charger is connected properly. else u need to check on the charging pin in the mobile.
Aug 20, 2009 | Nokia 1112 Cellular Phone
Unable to charge W270 Motorola with Moto V3 Charger.
Jul 18, 2009 | Motorola Cell Phones
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
Charging Battery
did u try to charge it connected to your pc? maybe its the charger
Feb 04, 2008 | Motorola Mobility Moto Q
Motorola Mobility RAZR V3c Cellular Phone Logo
284 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
