Question about Vacuums
Generation 4 Apparently, my belt came off while vacumming. I had a lot of hari entwind on the roller, so cleaned off the hair.... but now I can't seem to get the belt to stay "in place". Is it supposed to move around on the brush? or be held in place? It seems to me when I try to get the hook to grab ahold of the belt, it is going tohe wrong way to grab it. Please HELP!
    President:
  • 1,673 Answers
First off get a new belt, I am sure this one has stretched. Then put the belt around the brush roll, put it in the center, put the bottom plate back on. Then turn the big knob on the front and turn it until it locks, you will know if it grabbed the belt, it will be hard to turn. Then install the nozzle back on the vac, lock it down, turn the knob again and it will release the belt on he pulley.
Posted on Jun 22, 2008
I have a Shark navigator upright vacum NV22L 31. When I vacum the roller stops and starts spinning on and off. What could be the problem?
Well apart from it not being a Dyson? :>)
Usually two things.
The beater brush is not spinning freely due to hair and fluff at the bearing ends. Remove the brush and clean them.
Due to age, the belt has stretched or worn thin, or both. Change the belt every year.
Oct 10, 2017 | Shark Vacuums
I have a Dyson DC07. The roller wasn't spinning so I cleaned the brush of hair and fibers. That SEEMED to do the trick. But while vacuuming I noticed again that the roller brush was not spinning AGAIN. The...
You may need new belts. Belts lose elasticity from being stretched. The clutch must be removed and disassembled to change the belts. It's easier to replace the clutch. The belts will be tight and It's difficult without a special tool. While you have the brushroll out pull the shaft out of the center and clean hair and debris from it or replace brushroll if worn or frayed.
Dec 22, 2017 | Dyson DC07 Bagless Upright Cyclonic Vacuum
What makes the vacuum overheat shortly after turning it on?
There can be several problems causing the vacuum to over heat.
First, if the odor is similar to that of a car tire burning rubber...it is the belt rubbing on something. Unplug the vacuum, turn it upside down on a newspaper ot old towel to keep the mess down, and remove the cover plate that is over the roller bar. There are 2 screws~one on each side of the cover. Put the screws in a safe place like a ziplock. Check to see if there's a build up of hair on the roller. Cut it off with scissors. There could also be hair under the belt on the roller. The belt is very flexible and can be pushed to the side to access cleaning. An exacto or razor blade can be CAREFULLY used to cut this buildup.
If the odor is sweet electrical smell...unplug the vacuum immediatly and take it to a repair shop.
Oct 08, 2011 | Fantom Vacums FM741 Twister Bagless...
The belt has been replaced but the roller will still not turn. Should I try replacing the brush roller?
Remove the brush and clean the hair etc
from the end bearings, until they turn nice
and free
You have to have the correct belt and
install it right
Feb 03, 2011 | Eureka Whirlwind LiteSpeed 5843 Upright...
How do you change the belt
on the bottom of the vacume you should see about 4 screws ( philips ) that hold the plate in place, remove the screws and plate and this will expose the motor shaft,belt and roller ( you should also see the broken belt there two ) -- pop out the roller ( pull straight up ). put new belt onto the motorspindle and then onto the roller, snap roller back into place ( note: on the edges of the roller it is somewhat keyed to only fit into the vacume a certain way ), replace the the plate and screws and you are good to go. also while you are getting dirty -- clean the air filter and examine the hose between the floor roller and the suction hose for dirt build up and debris.
c...
Jan 01, 2011 | Dirt Devil M086700 Vision Bagless Upright...
Hi, my kirby makes a very loud and rattly noise when im vacuming, and sometimes the roller brush stops working, please help thank you
replace fan,belt and either clean ends of rollerbrush of string, hair, floss, etc or buy a new rollerbrush
Dec 08, 2010 | Kirby G5 Bagged Upright Vacuum
Hair getting stuck in the belt drive area causing beater to skip
Hair,string, tinsel, etc. have always been problems for rollers and belts. You will have to remove the hair. It can often get stuck at the ends of the rollers also and keep the roller from turning. I usually remove the roller and clean it using a screwdriver, knife, etc. to remove the hair. the cleaning can be done while the roller is still on the unit by turning the unit over although this may not offer as much free access to the roller. Of course, removing the roller means removing the belt and if you are not up to this (I don't know how handy you are), I would try to remove the hair with the roller on. If you do this, be careful not to put any nicks in the belt. Good luck!
Mar 13, 2010 | Dyson Vacuums
Kirby Generation 3
PUll the roller brush out and make sure it turns freely by hand. If not clean all hair and debris off the roller brush, you might also remove the end caps (one at a time) and clean the hair out from the bearings underneath the cap (in the shop I use WD-40 and a non-serated pairing-knife). Replace caps they only go one way. If you can not free up the brush you'll have to replace it.
If the brush spins freely probably just need a new belt they stretch out over time.
Jul 04, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Belt not turning
It could well be the dog hair. You'll need to remove the roller brush and completely clean it off with the hair which sounds like it has wrapped itself around the brush and the brush end washers. Check that the entire roller brush is completely clear and if any dirt is found at the sides, remove it.
Mar 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
