I can't get my wireless headphones to worl wiht my LG 42PG
There does not appear to be an "Audio Out" or a Headphone Jack I can connect my wireless headphones to
    Novelist:
    Scholar:
  • 100 Answers
Salutations Derek23,
Unfortunately that is correct, most newer televisions do not come with "Audio Out" or headphone jacks. Its almost assumed that you would be connecting the television to a receiver or audio source of some type that would have these types of connections.
Sorry to break the bad news.
Jon
Go Ahead. Use Us.
Posted on Jun 24, 2008
I want to connect a Sony Wireless headphone to the receiver w/o disabling the speakers.
Normally you shuould connect the headphone inserting the plug in receiver's jjack. If you've gou no jack, you can't use the headphone
Jun 02, 2015 | Onkyo TX-DS474 Receiver
Tip
LG ENV as a touch connecting to an additional input
<p>You can use the 3.5 mm headphone jack on the Touch LG ENV to an audio device via an auxiliary input. If the audio cable is connected, the phone automatically updates all sounds cable. Then you can play music from the music player devices, such as car radios and systems external speaker. The 3.5 mm audio jack is a stereo connection, and is the audio standard for many electronic devices. <br /> <p><br /> <p>1. Connect one end of the audio cable to the 3.5 mm headphone jack on the Touch LG ENV. <br /> <p><br /> <p>2. Connect the other end of the cable into the auxiliary input device you are connecting. <br /> <p><br /> <p>3. Change the input of your audio device to take extra. Car radio, press the AUX button. See the device manual for specific instructions. <br />
on Aug 05, 2011 | Cell Phones
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
Good morning. Can I connect a wireless headphone to the digital audio output?
do you have any ideas on how to get my headphone jack on my television to work for wireless headphones
Jun 20, 2014 | Mitsubishi WD-73837 73 in. HDTV
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
HOW TO CONNECT HEAD PHONES TO TV
is it a wireless headphone or a wired one..??
genrally wired headphone use 3.5 mm audio jack ... try to find the 3.5 mm jack input on your tv and connect the headphone..
Sep 09, 2013 | Televison & Video
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
The vizio e322vl headphone jack is not documented by Visio. There is an "Audio" spot next to "RGB PC" and I tried various jack sizes b none works. If you have a soulution, can you...
that audio jack is input only it is stereo jack to connect from the comptuer to the tv when using the RGB input. most headphone jacks if they are there would be on the side of flat panel tvs. otherwise the audio output may be digital(optical) or normal rca (red and white) that you can hookup to the headphone system.
Dec 23, 2010 | Vizio E322VL 32 in. LCD TV
Want a TV wireless headphone with no headphone jack or audio out
You may have to connect the headset through a VCR or DVD player that does have the output connections.
Sep 05, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Televison & Video Logo
863 people viewed this question
Top Televison & Video Experts
