12 year old Sony TV won't work when on it's stand, but works when removed from stand and placed on the floor. It was fine for 12 years. The problem when on the stand is that it swicthes off immediately after turning it on.
  • 8,617 Answers
Solder connections. The older sonys had issues with solder around the flyback , HV transformers and yoke plugs. Check the solder connections all around the HV areas.
Posted on Jun 22, 2008
My Dyson - DC14 won't push on my new plush carpet, front end
Same issue: new plush carpet, 7 year old tried and true DC14, wouldn't push across regardless of beater brush on or off. Called Dyson this morning, they suggested removing the small gasket between the floor plate and the assembly holding the beater brush. It's about a 12' gasket just under the screws used to remove the floor plate. Pushing is still a bit stiff, but it is a definite improvement. Whew!
Jul 29, 2012 | Vacuums
TV WON'T POWER ON
The problem is in the power supply board, bad solder joints, or one or two failing capacitors, common issues.
Mar 10, 2012 | Philips 32PT41B 32" TV
I have a black approx 12 inch streak on the left side(facing tv) of my flat screen Bravia Sony TV . It is approximately 3 years old. It started as a brown panel..then became a fine lined multy colored...
sadly you have a bad panel. Sony panels carry a two year warranty.
your best hope is to call Sony and ask for a warranty extension to cover the cost of the part.
Apr 12, 2011 | Sony Bravia KDL-40Z4100 40 in. LCD TV
My 12 year old daughter accidentially put dish liquid in my dishwasher instead of dishwasher detergent. What do I do?
Can't see this doing too much harm in the long term.
Biggest problem is likely to be that it will froth a bit.
Suggest you run the machine empty on a "rinse and hold" cycle a couple of times. Stand by with a cloth and bucket, so that if the machine does froth up, you can mop up anything that seeps out before it makes a mess on the floor (watch the waste water outlet at the back as well as the front door.
Question: How on earth did you get your 12 year old daughter to put anything in the dishwasher in the first place - it's all I can do to stop mine leaving dirty crockery in her bed!
A.
Dec 17, 2008 | Dishwashers
Lifestyle 12 speaks - new HDTV
mount to wall, brackets available to purcahse on loads of on line sites. and from bose direct cost 5 dolurs to 50 dollars eack depending how fancy you want to be.
would recomment also distancing the left right satellites as you will be amazed how much improvement in sound is gained from a well defined centre channel.
also if you want to be really smart. its really not necessary to see the centre satelliet and it could simply sit of the stand behind the tv. with no problem. plus you could use the tv audio input to make the tv as a centre channel. you would be surprised how well that works. make sure you disable the tvs steroe function or your surround sound will not sound too surround....
finally if you have lifestyle series II make sure you conect the 5.1 input to the bass box to your tv. and get rid of the bose cd player , put it out of sight, and loose the remote. will work even better than it did before !
Jan 02, 2008 | Bose Lifestyle 12 System
PS3 video output on SD tv is wavy with discoloration and black line
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Televison & Video Experts
