Soft High pitch whinning
A soft high pitch whinning coming from left bottom. Either light or fan area?
  • billdante Jun 22, 2008
    I thought the model is HLM617W
    The noise does stop as soon as set is turned off. Also, no lights are blinking on front of set to indicate any lamp problem. I have replaced the lamp a year ago.
    Thanks
  • 8,617 Answers
I would need the model number of your set to even begin helping you with the problem. Please respond to this post so I will have your sympton still available along with your model number.
Posted on Jun 22, 2008
  • Sonny Berry
    Sonny Berry Jun 22, 2008
    If your refering to the bottom left as viewed from the front of the set it can be the cooling fan for the lamp. Is the whinning constant ? Does it continue after shutting unit off ? If so that would be indicating the fan as the cooling fan will continue to run after the set is shut down. If it stops whinning at shut down that would lead me to suspect the color wheel being in the early stages of bearing failure.
  • Sonny Berry
    Its the color wheel if it stops. Thats located right in front of the lamp after the small glass panel. Its under the ribbed section.
High beam headlamps inop
do you have halogen or hid lights sounds like a ballast or ground issue more info!!
Jan 02, 2018 | 2010 Toyota Avalon
When The TV is running it makes a high pitched whinning that seems to be coming from the projector
its a bad color wheel and you may be able to replace it. You Tube has videos for this.
Look where the lamp faces and see if wheel missing segments or shattered.
Nov 27, 2012 | Samsung HLM5065W 50" Rear Projection...
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
Rattles on high speed and soft click click sound on low how do you get to the fan
Assuming you're talking about the HVAC blower motor, it is located behind the glovebox. There is a plastic access panel under the passenger side dash area, take this off and also open glovebox and release tab in left corner. This will allow you to see the motor. See picture below.
Sep 01, 2011 | 2004 GMC Envoy
Making high pitch whine or squeeling
Check the color wheel and any fans running on the unit. The color wheels make a high pitch whin right before they quit as well as the cooling fans.
Jul 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Loud noise!
May be a bad bearing on belt tensioner or idler pully
Feb 13, 2010 | 2000 Jeep Grand Cherokee
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
