Question about Dishwashers
We need instructions on how to use a used dishwasher we got. we don't know if its a piece of **** or if we're using it wrong. i cannot find a website for this dishwasher anywhere.
  • 38 Answers
Whats the make of it pleas
Posted on Jun 24, 2008
I forgot to open the dishwasher hole when installing. I don;t have the instructions and I can't figure out what I am supposed to do. It seems solid and I don;t see anything removable
If you disconnect the dishwasher hose from the disposal and peek inside the disposal where the hose was, you'll see that it's blocked by a piece of plastic. It's premolded into the inner chamber but that portion is breakable. Stick a screwdriver or something into the hole and give it a whack. If that piece end up inside the disposal's main compartment, you'll need to get it out. You could turn the disposal upside down if you haven't already installed it, but you did.
Aug 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Adjustable wrench
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    Dishwasher will not drain out. Is it a clogged drain, bad pump or something else. Model # DU1015XTXS2, Serial # F05301668 and the Type # 575-1. Where is the drain plug located? I have not used this...
    Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
    Jul 05, 2011 | Whirlpool Dishwashers
    How to remove water input assembly
    If you are talking about the plastic molded piece on the outside of the dishwasher tub where the water inlet hose runs to, this piece does not come off. Its a permanent molded piece of the tub. If you break it, you have to replace the entire tub. The build up of water scale and deposits is a common problem in this area. If you remove the rubber hose and use a small screwdriver or small brush (the kind you would use for cleaning gun barrels) this is sufficient to get most of the deposits free. Flush with distilled vinegar and hot water. If I'm wrong in assuming this is what you're talking about, please post back and let me know. I hope this helps you.
    Aug 06, 2008 | KitchenAid 24 in. KUDI02IR Built-in...
    I think there used to be a metal hanger-like piece of **** holding down the bag at the spot where it is affixed to the vacuum cleaner. I want to find it, and if possible, download the **** manual. Too much... Generic problem for all Vacuums I think there used to Posted by imaninvisibl on Apr 30, 2008 I think there used to be a metal hanger-like piece of **** holding down the bag at the spot where it is affixed to the vacuum cleaner. I want to find it, and if possible, download the **** manual. Too much to hope for? Hoover Legacy 830.....Model # U5079-910......Serial # 069100005664. Please don't tell me it's SO old they deny ever having made the thing! Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Legacy 830 – Model #U5079-910 The vacuum model is not that old and I would suggest that you contact your local vacuum dealer to see if they have a new or a good used metal piece that would work or contact the Hoover Co and they could send you a owners manual or instruct you to download the manual from the Hoover website. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone Contact our Customer Service Department at 1.330.499.9499 Monday through Friday 8 a.m. - 7 p.m. EST 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS. Don – The Vac Man Go Ahead. Use Us.
    Apr 30, 2008 | Vacuums
    I need help disassembling it.
    You should be able to find instructions on how to dissassemble the laptop on the HP support website, but honestly I don't know what you'll be able to salvage to use for a desktop other than the hard drive.
    Nov 30, 2007 | HP Compaq Evo Notebook N600c
    Dishwashers Logo
    Top Dishwashers Experts
