Question about Samsung LN-T4061F 40 in. LCD HDTV
Connecting HD cable box to DVR too HDTV
I have a Samsung LNT-4061F hdtv and a Sony RDR GX330 DVR.  Comcast provided a Motorola DCH 3200 box to get the hd signal.
Maybe I need to upgrade the DVR, but I can't get a signal to the TV going through the DVR.  It only works when it goes directly from the hd cable box to the TV.  This means that to record a DVD, we have to connect the cable directly to the DVR bypassing the cable box, and we can't watch another channel on TV while recording.
Is this because the DVR is not appropriate for HD?
Also, I a an S-video cord that I'm not using, also HDMI that I'm not using because it doesn't seem to work.  I'm using the RGB cords to connect the cable box directly to the TV bypassing the DVR.  This works fine for watching TV but obviously not for recording.
Help!
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Posted on Jul 15, 2008
This dvd recorder worked PERFECTLY when I had digatal cable. As soon as I up graded to HD with a HD box from comcast, I cannot get the recorder to record anything. I hooked it up the same way as I did with...
The HD box from your cable company only sends High Definition Video signal which DVD does not support. Your DVD recorder "CANNOT RECORD THIS PICTURE" because it can not process (see) the High Definition (HD) Signal.
To record from an HD reviver you would need a HD recorder (Blu-ray) very expensive The standard practice for recording from a HD cable receiver id to use an DVR here is a link to one for about $100 some models will have a standard video output you could connect your dvd recorder to.
http://www.google.com/products/catalog?q=HD+Dvr&oe=utf-8&client=firefox-a&hl=en&cid=15241578777457062393&ei=puGPTNuoFIm4iwSJ2s1h&sa=title&ved=0CBcQ8wIwATgA#p
Sep 14, 2010 | Sony RDR-GX330
I have a DVR from Comcast hooked to the tv; what else is needed to view in HD. It is a Philips 60" projection HDTV (model 60pp9202) and how can I get a replacement owner's manual?
u need to ask ur cable provider what kine of service u have , not all cable boxes are hd , for ur owner manual just google , some may have this for free
Apr 13, 2010 | Philips 60PP9202 60" Rear Projection...
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung LN-T4061F 40 in. LCD HDTV Logo
505 people viewed this question
Henry  Thomas
Henry Thomas
