Question about HP Office Equipment & Supplies
Hp deskjet printer640c/colorcartridge no 49
The original cartridge was exhausted so i bought a new one[ no 49].i fixed along with b/w cartridge no 20[newone].i swtched on the printer but the printer gets stuck in between/doesnt return back completely.so i cant use the printer. so i removed the new no 49 and put back the old one .ow it works the printer head goes back to its place completely.and the printer works. where have i gone wrong?what care should i take while fixing the cartridge in its slot? can u help me please? yours jayaram[india]
  • mvjayarammv Jun 23, 2008
    thanks my friend. i had already tried all that u have advised, but the problem persists. i have to tell u that it hadworked properly for some days. i had not used the printer for some days after that. then when i tried, the problem came on again which had happened immediately after i had bought the cartridge and nstalled it.i had tried some tricks through the printer software in my laptop and it had worked. now the problem has arisen again. have any ideas? jayaram
    Novelist:
    Scholar:
  • 70 Answers
Sounds like either part of the tape that covers the cartridge (you did remove the tape right?) is still stuck on it and it didn't seat right. Was it harder (applied more force) to latch the new cartridge in place than the old one? If so then there is something either stuck on the new cartridge foot or nozzle face.
Another explaination is that the foot came off the old cartridge and is still in the printer. This happens some times. Examine the new and old cartridge carefully. Are they different? How?
Remove both cartridges and look at the emply holes where they were. See the metal pins? Is anything covering them? Remove any tape or pieces of tape carefully.
Posted on Jun 22, 2008
  • Kim Parker
    Kim Parker Jun 23, 2008
    I have had similar problems with the driver for printers and scanners. How about deleting your printer and it's drivers and reinstalling them. Have you already tried that?
What is an OEM cartridge?
OEM (pronounced as separate letters) is short for original equipment manufacturer
The Cartridges for the HP DeskJet 3740 InkJet Printer are:
HP 27 Black Original Ink Cartridge
HP 28 Tri-color Original Ink Cartridge
These can be purchased from your local store that sells HP Printers & ink or by going to HP.com and ordereing direct from the Manufacturer
May 01, 2014 | HP DeskJet 3740 InkJet Printer
I am having a hp deskjet printer model d 1668 and the ink in the cartridge was exhausted before one month and i removed the cartridge./ now i bought a new cartridge but the systems shows there is a error...
A cleaning will fix the problem. To clean your Canon HP D1668 > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
Hope this help, thanks!
Oct 08, 2011 | Office Equipment & Supplies
My HP3920 Deskjet printer does not print color although I have color ink 22 installed along with the black. How do I fix this?
You need to use only cartrigde original not refill or compatible.If you have original cartridge try to look at the purge unit,is on the rigth,possible is clogged and you need to replace.
Mar 23, 2011 | HP DeskJet 3930 InkJet Printer
Error: wrong colorcartridge installed.
If you are using a refilled cartridge (worst possible decision) or a third party cartridge (2nd worst possible choice) that is the mosrt probable cause of your failure.
If you are using a factory new HP cartridge call the store where you purchased the cartridge and tell them you have a defective cartridge.
Don
Feb 26, 2010 | HP PSC 750 All-In-One InkJet Printer
Cartridge empty light
A few basic causes.
1. The cartridges you bought iwere not proper HP ones and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printerthrough the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
Run your printers alignment test
I would suspect number 1.
If you found this information useful please click below
Aug 12, 2009 | HP DeskJet 1280 InkJet Printer
I buy until now 5 hp351 colorcartridge, after few days is "dead"
Sounds like the problem is that you are refilling the cartridges. Each HP cartridge has a special chip on it that will only read the original ink supply properly. Try a brand new cartridge that has never been refilled and see if that makes a difference.
Jul 26, 2009 | HP Photosmart D5360 InkJet Printer
HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Jun 01, 2009 | HP DeskJet F4280 All In One Printer InkJet
How can I fix my HP Deskjet F4280 cartridge error message?
hi..i have similar problem with anjulyn80..i bought a new cartridge but still got a cartridge error in it..
Feb 18, 2009 | HP DeskJet 3740 InkJet Printer
Hepl me find and download a driver
Firstly make sure that they are original cartridges as most problems are caused by faulty cartridges. Then clean the gold contacts with a soft cloth. install cartridges and turn machine on hopefully this will work if not then the machine has a carriage fault.
Hope this helps you
Thanks J
Dec 10, 2007 | HP DeskJet 845c Printer
Ben Johnson
